Huawei u7519 Back Cover Replacement
  1. Huawei u7519 Back Cover Replacement, Back Cover: step 1, image 1 of 2 Huawei u7519 Back Cover Replacement, Back Cover: step 1, image 2 of 2
    • Take off the back covering of the phone along with the battery and SIM card.
    • The SIM card is located above the battery.
  2. Huawei u7519 Back Cover Replacement: step 2, image 1 of 2 Huawei u7519 Back Cover Replacement: step 2, image 2 of 2
    • Using the Phillips #00 Screwdriver, take out the four small screws located at the four corners of the phone.
    • Save the screws. They will be needed for reassembly.
  3. Huawei u7519 Back Cover Replacement: step 3, image 1 of 1
    • Using the same screwdriver, take out the two bigger screws located on each side of the battery compartment.
  4. Huawei u7519 Back Cover Replacement: step 4, image 1 of 1
    • Once all the screws are removed, use the iPod opening tool to pry off the back covering of the phone along the edge of the back cover and you will have access to the motherboard.
    • The power and volume buttons will fall out of the phone. Set aside for reassembly.
  5. Huawei u7519 Back Cover Replacement: step 5, image 1 of 1
    • Carefully pull the backing of the phone from the motherboard with your hands.
2 other people completed this guide.
Savanah Anik
77 Reputation
1 Guide authored
Ohio State, Team 1-1, Meza Spring 2014 Member of Ohio State, Team 1-1, Meza Spring 2014
OSU-MEZA-S14S1G1
4 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 13
All Time: 660
