Huntington GA41PS-RDS Acoustic Guitar String Replacement
  1. Huntington GA41PS-RDS Acoustic Guitar String Replacement, Guitar String: step 1, image 1 of 1
    • Place your guitar on a flat surface where you can easily identify the broken string.
  2. Huntington GA41PS-RDS Acoustic Guitar String Replacement: step 2, image 1 of 3 Huntington GA41PS-RDS Acoustic Guitar String Replacement: step 2, image 2 of 3 Huntington GA41PS-RDS Acoustic Guitar String Replacement: step 2, image 3 of 3
    • Rotate the guitar pegs counter clockwise to loosen the broken string, until it can be removed by hand.
  3. Huntington GA41PS-RDS Acoustic Guitar String Replacement: step 3, image 1 of 2 Huntington GA41PS-RDS Acoustic Guitar String Replacement: step 3, image 2 of 2
    • Remove the bridge pin located at the lower end of the guitar.
    • Remove the other end of the broken string carefully. Keep the bridge pin removed.
  4. Huntington GA41PS-RDS Acoustic Guitar String Replacement: step 4, image 1 of 3 Huntington GA41PS-RDS Acoustic Guitar String Replacement: step 4, image 2 of 3 Huntington GA41PS-RDS Acoustic Guitar String Replacement: step 4, image 3 of 3
    • Take the ball end of the new string and insert it into the bridge hole.
    • Insert the bridge pin back into the hole. Pull the rest of the string slightly to make sure it is tight.
    • Select the correct string to replace. I will be using the thinnest E string for this guide
  5. Huntington GA41PS-RDS Acoustic Guitar String Replacement: step 5, image 1 of 3 Huntington GA41PS-RDS Acoustic Guitar String Replacement: step 5, image 2 of 3 Huntington GA41PS-RDS Acoustic Guitar String Replacement: step 5, image 3 of 3
    • Take the pointed end of the string and insert it into the string post.
    • Allow excess string to pass through. Tug on the string and make sure the string is parallel to the fret board.
    • Be careful. Do not hold too close to the sharp end of the string.
  6. Huntington GA41PS-RDS Acoustic Guitar String Replacement: step 6, image 1 of 3 Huntington GA41PS-RDS Acoustic Guitar String Replacement: step 6, image 2 of 3 Huntington GA41PS-RDS Acoustic Guitar String Replacement: step 6, image 3 of 3
    • Make one loop around the string post with the excess string.
    • Rotate the tuning peg clockwise to tighten the string.
  7. Huntington GA41PS-RDS Acoustic Guitar String Replacement: step 7, image 1 of 2 Huntington GA41PS-RDS Acoustic Guitar String Replacement: step 7, image 2 of 2
    • Trim the excess string with the pliers. Make sure to cut close to the string post so it does not stick out.
Ruhail Khan
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 38
All Time: 800
