HyperX Alloy Origins Backplate Replacement
  1. HyperX Alloy Origins Backplate Replacement, Toggle Indicator Tab: step 1, image 1 of 1
    • Locate the toggle indicator tab on the top right corner of the keyboard.
  2. HyperX Alloy Origins Backplate Replacement: step 2, image 1 of 2 HyperX Alloy Origins Backplate Replacement: step 2, image 2 of 2
    • Insert the metal spudger or some other separating instrument into the right crevasse between the tab and the keyboard.
    • Lift up gently on the tab, while holding the left side of the tab down.
    • The tab can spring upwards upon removal. Eye protection is recommended during this step.
  3. HyperX Alloy Origins Backplate Replacement, Backplate: step 3, image 1 of 2 HyperX Alloy Origins Backplate Replacement, Backplate: step 3, image 2 of 2
    • Flip the keyboard over so that the backplate is facing you.
  4. HyperX Alloy Origins Backplate Replacement: step 4, image 1 of 3 HyperX Alloy Origins Backplate Replacement: step 4, image 2 of 3 HyperX Alloy Origins Backplate Replacement: step 4, image 3 of 3
    • Remove the rubber feet on the four corners of the backplate.
    • When reassembling, use an adhesive to reattach the feet. A silicone rubber adhesive is recommended.
  5. HyperX Alloy Origins Backplate Replacement: step 5, image 1 of 3 HyperX Alloy Origins Backplate Replacement: step 5, image 2 of 3 HyperX Alloy Origins Backplate Replacement: step 5, image 3 of 3
    • Remove the specified keycaps as depicted in the image.
  6. HyperX Alloy Origins Backplate Replacement: step 6, image 1 of 3 HyperX Alloy Origins Backplate Replacement: step 6, image 2 of 3 HyperX Alloy Origins Backplate Replacement: step 6, image 3 of 3
    • Remove all Philips #0 screws from the new openings created after removing the rubber feet and plastic tab.
  7. HyperX Alloy Origins Backplate Replacement: step 7, image 1 of 3 HyperX Alloy Origins Backplate Replacement: step 7, image 2 of 3 HyperX Alloy Origins Backplate Replacement: step 7, image 3 of 3
    • Separate the backplate from the keyboard using your hands.
Mario Ricci
294 Reputation
2 Guides authored
UMass Dartmouth, Team 5-2, Sinclaire Fall 2022 Member of UMass Dartmouth, Team 5-2, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S5G2
5 Members
15 Guides authored
1 Guide Comment
my plate was scratched due to being separated using a metal screw driver, do you have any recommended paints to go over the scratched areas with?
Damian Burton - Reply Share
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 46
All Time: 1,776
