HyperX Alloy Origins HX-KB7RDX-US Disassembly
  1. HyperX Alloy Origins HX-KB7RDX-US  Disassembly, HyperX Alloy Origins Dissassembly: step 1, image 1 of 1
    • Turn the keyboard over so you can see the warranty sticker.
    • Remove the rubber foot from the upper right keyboard stand to expose the machine screw. Then remove the screw.
  2. HyperX Alloy Origins HX-KB7RDX-US  Disassembly: step 2, image 1 of 1
    • Remove all of the keys to expose the 16 black self tapping screws then remove the screws.
    • Be sure to save the screws in one place. They are easy to lose.
  3. HyperX Alloy Origins HX-KB7RDX-US  Disassembly: step 3, image 1 of 1
    • Gently pry the casing away from they top to expose the PCB.
4 other people completed this guide.
Alexander Lang
181 Reputation
1 Guide authored
4 Comments
Do you happen to know the pinout for the RGB light? Also, the copper trace for the space bard RGB? My RGB pad on the space bar was lifted during de-soldering to fix the stabilizer. The copper trace seems to be the most different in the space bar LED. I need to find the trace to create a new connection to the RGB for the space bar
Cin Lung Chen - Reply
I could probably work it out for you. It would help if you shared pictures of the lifted trace. In order to effect a repair you will need a soldering iron, solder and flux. You will also need some aircraft or kynar wire (really thin wire). Do you have a multimeter with continuity tester?
Alexander Lang -
How do I get the pcb board off?
Ford - Reply
i dont know how or exactly why, but mine started to rust on the side, next to the shift and caps lock key, im going to try to remove the rust and repaint if there is any good metal sheet left after sanding
Sebastian Casella - Reply
Past 24 Hours: 14
Past 7 Days: 144
Past 30 Days: 723
All Time: 14,830
