Introduction
If you are having trouble with your microphone receiving power or any function whatsoever, it could be a problem with your I/O board. This is a fairly easy fix, however; all you have to do is replace it. Follow this straightforward guide to access your microphone’s I/O board with ease. While some cables unplug easily, some will need to be removed from the board entirely. Keep in mind that this guide will not cover how to resolder any disconnected cables.
Set the microphone on a flat surface.
Pull each of the support bands upwards and off of the notches to release the microphone from its base.
2 Comments
I need a replacement io board, does ifixit or anyone else have them?
Unfortunately HyperX does not sell the replacement parts separately. Your best bet is to find a scrap quad-cast to pull parts from.
