HyperX QuadCast S Mute Sensor Replacement
  1. HyperX QuadCast S Mute Sensor Replacement, Tap-To-Mute Sensor: step 1, image 1 of 3 HyperX QuadCast S Mute Sensor Replacement, Tap-To-Mute Sensor: step 1, image 2 of 3 HyperX QuadCast S Mute Sensor Replacement, Tap-To-Mute Sensor: step 1, image 3 of 3
    • Set the microphone on a flat surface.
    • Pull each of the support bands upwards and off of the notches to release the microphone from its base.
    • There are four support bands in total, but it does not matter which band you choose to take off first.
  2. HyperX QuadCast S Mute Sensor Replacement: step 2, image 1 of 3 HyperX QuadCast S Mute Sensor Replacement: step 2, image 2 of 3 HyperX QuadCast S Mute Sensor Replacement: step 2, image 3 of 3
    • Grab ahold of the tap-to-mute Sensor and pull it upwards in a clockwise motion.
    • Be careful not to damage the cable as you remove the top.
    • Once the tap-to-mute sensor detaches from the microphone, you will hear a small "pop."
  3. HyperX QuadCast S Mute Sensor Replacement: step 3, image 1 of 3 HyperX QuadCast S Mute Sensor Replacement: step 3, image 2 of 3 HyperX QuadCast S Mute Sensor Replacement: step 3, image 3 of 3
    • Gently unplug the cable, and remove the tap to the Tap-To-Mute sensor from the microphone.
    • The square indicates the location of the cable. This is cable is very small and will require a bit of force to be unplugged.
2 other people completed this guide.
Nathan Arruda
765 Reputation
6 Guides authored
4 Guide Comments
Nice guide, but I've been unable to find a replacement.
Is the tap sensor from the Quadcast (the non-S version) compatible?
P S - Reply
I believe it should be compatible. The S version should just be different with its illumination and USB charging so the tap-to-mute sensor should be the same. Unfortunately, it's hard to source replacement parts since hyperx does not sell them separately. I could only recommend buying a used hyperx microphone for cheap and scraping the parts for replacement. Hope that helps.
Nathan Arruda - Reply
what is the cable order to put them back in. i have a yellow, red, white, and black cable
Jeremy Ray - Reply
Donde puedo comprar una remplazo de la Quadcast S TOUCH BOARD.V1 w45/19.hz?
Eladio Valencia Meneses - Reply
Past 24 Hours: 5
Past 7 Days: 25
Past 30 Days: 94
All Time: 4,990
