HyperX QuadCast S Pop Filter Replacement
  1. HyperX QuadCast S Pop Filter Replacement, Tap-To-Mute Sensor: step 1, image 1 of 3 HyperX QuadCast S Pop Filter Replacement, Tap-To-Mute Sensor: step 1, image 2 of 3 HyperX QuadCast S Pop Filter Replacement, Tap-To-Mute Sensor: step 1, image 3 of 3
    • Set the microphone on a flat surface.
    • Pull each of the support bands upwards and off of the notches to release the microphone from its base.
    • There are four support bands in total, but it does not matter which band you choose to take off first.
  2. HyperX QuadCast S Pop Filter Replacement: step 2, image 1 of 3 HyperX QuadCast S Pop Filter Replacement: step 2, image 2 of 3 HyperX QuadCast S Pop Filter Replacement: step 2, image 3 of 3
    • Grab ahold of the tap-to-mute Sensor and pull it upwards in a clockwise motion.
    • Be careful not to damage the cable as you remove the top.
    • Once the tap-to-mute sensor detaches from the microphone, you will hear a small "pop."
  3. HyperX QuadCast S Pop Filter Replacement: step 3, image 1 of 3 HyperX QuadCast S Pop Filter Replacement: step 3, image 2 of 3 HyperX QuadCast S Pop Filter Replacement: step 3, image 3 of 3
    • Gently unplug the cable, and remove the tap to the Tap-To-Mute sensor from the microphone.
    • The square indicates the location of the cable. This is cable is very small and will require a bit of force to be unplugged.
  4. HyperX QuadCast S Pop Filter Replacement, Pop Filter: step 4, image 1 of 1
    • Once the Tap-To-Mute sensor has been removed, you will now have access to the pop filter.
    • The pop filter is just the grey foam surrounding the inside of the microphone.
  5. HyperX QuadCast S Pop Filter Replacement: step 5, image 1 of 1
    • The pop filter will be in a fixed position being glued to the wire. Remove glue residue before continuing to remove the pop filter.
    • When you replace the pop filter, remember that you will need to glue it back into place as before.
  6. HyperX QuadCast S Pop Filter Replacement: step 6, image 1 of 2 HyperX QuadCast S Pop Filter Replacement: step 6, image 2 of 2
    • Reach into the microphone and remove the pop filter.
Nathan Arruda
765 Reputation
6 Guides authored
3 Guide Comments
"Grab ahold of the tap-to-mute Sensor and pull it upwards in a clockwise motion."
This part is keyed. It literally cannot be pulled in any rotational motion...
Kyle Villalovos - Reply
Is there a place where you recomend i can get a replacement peice of foam for the pop filter. I cant find one anywhere online.
Liam Henesy - Reply
did you happen to find anything?
Kamen C-Swartz -
Past 24 Hours: 5
Past 7 Days: 26
Past 30 Days: 100
All Time: 3,826
