IBM ThinkPad 600E Keyboard Replacement
  1. IBM ThinkPad 600E Keyboard Replacement, Battery: step 1, image 1 of 3 IBM ThinkPad 600E Keyboard Replacement, Battery: step 1, image 2 of 3 IBM ThinkPad 600E Keyboard Replacement, Battery: step 1, image 3 of 3
    • Flip the laptop over and find the battery latch.
  2. IBM ThinkPad 600E Keyboard Replacement: step 2, image 1 of 1
    • Move the latch to the side with the unlocked symbol.
  3. IBM ThinkPad 600E Keyboard Replacement: step 3, image 1 of 3 IBM ThinkPad 600E Keyboard Replacement: step 3, image 2 of 3 IBM ThinkPad 600E Keyboard Replacement: step 3, image 3 of 3
    • Pry the battery out using your fingers.
  4. IBM ThinkPad 600E Keyboard Replacement, Keyboard: step 4, image 1 of 3 IBM ThinkPad 600E Keyboard Replacement, Keyboard: step 4, image 2 of 3 IBM ThinkPad 600E Keyboard Replacement, Keyboard: step 4, image 3 of 3
    Tool used on this step:
    Anti-Static Wrist Strap
    $7.95
    Buy
    • Use an antistatic wrist strap to avoid the risk of electric shock.
    • Unscrew the coin screw for the hard drive using a coin. Pry off the HDD cover.
    • It is easier to remove the coin screw using a thicker coin, such as a nickel.
  5. IBM ThinkPad 600E Keyboard Replacement: step 5, image 1 of 3 IBM ThinkPad 600E Keyboard Replacement: step 5, image 2 of 3 IBM ThinkPad 600E Keyboard Replacement: step 5, image 3 of 3
    • Unlock the highlighted latch and pull the disk drive out.
    • Remove the disk drive.
  6. IBM ThinkPad 600E Keyboard Replacement: step 6, image 1 of 3 IBM ThinkPad 600E Keyboard Replacement: step 6, image 2 of 3 IBM ThinkPad 600E Keyboard Replacement: step 6, image 3 of 3
    • Most of the screws have a small, plastic covering attached with an adhesive. Use the metal spudger to pry it off. Make sure to note which screw came from which hole.
    • Four 18mm long M2.5 screws
    • Two 16mm long M2.5 screws
    • One 4.5mm long M2.5 screws
    • Four 3mm long M2.5 screws
  7. IBM ThinkPad 600E Keyboard Replacement: step 7, image 1 of 2 IBM ThinkPad 600E Keyboard Replacement: step 7, image 2 of 2
    • Open the laptop all the way until it is flat.
    • Take the black circle off and remove the screw.
  8. IBM ThinkPad 600E Keyboard Replacement: step 8, image 1 of 3 IBM ThinkPad 600E Keyboard Replacement: step 8, image 2 of 3 IBM ThinkPad 600E Keyboard Replacement: step 8, image 3 of 3
    • Pry the keyboard case up from the bottom and gently pry it up from all other edges.
    • Use caution when opening the case, as there are two ribbon cables attached to the keyboard case.
  9. IBM ThinkPad 600E Keyboard Replacement: step 9, image 1 of 3 IBM ThinkPad 600E Keyboard Replacement: step 9, image 2 of 3 IBM ThinkPad 600E Keyboard Replacement: step 9, image 3 of 3
    • Pry the connectors of the ribbon cables off slowly, lifting straight up. Wiggle gently side to side if necessary.
3 other people completed this guide.
Kevin Nguyen
737 Reputation
4 Guides authored
USF Tampa, Team 1-4, Nance Fall 2016 Member of USF Tampa, Team 1-4, Nance Fall 2016
USFT-NANCE-F16S1G4
4 Members
12 Guides authored
1 Guide Comment
Thank you. Unfortunately it didn't help. Otherwise great instructions. Because I wanted to replace the BIOS battery on the 600e ibm think pad to know if there was anything on the laptop at the time. Unfortunately I couldn't get it opened again. And since I didn't want to force it open, I screwed the notebook back together and put it away.
Hymurwa - Reply
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 40
All Time: 2,358
