IBM ThinkPad 600E RAM Replacement
  1. IBM ThinkPad 600E RAM Replacement, Battery: step 1, image 1 of 3 IBM ThinkPad 600E RAM Replacement, Battery: step 1, image 2 of 3 IBM ThinkPad 600E RAM Replacement, Battery: step 1, image 3 of 3
    • Flip the laptop over and find the battery latch.
  2. IBM ThinkPad 600E RAM Replacement: step 2, image 1 of 1
    • Move the latch to the side with the unlocked symbol.
  3. IBM ThinkPad 600E RAM Replacement: step 3, image 1 of 3 IBM ThinkPad 600E RAM Replacement: step 3, image 2 of 3 IBM ThinkPad 600E RAM Replacement: step 3, image 3 of 3
    • Pry the battery out using your fingers.
  4. IBM ThinkPad 600E RAM Replacement, RAM: step 4, image 1 of 1
    • Put on the anti-static wrist trap and clip it to a large metal object.
    • If you do not have an anti-static wristband, make sure to touch a large metal object to ground yourself before beginning to work on your replacement. Occasionally touch the metal object.
  5. IBM ThinkPad 600E RAM Replacement: step 5, image 1 of 3 IBM ThinkPad 600E RAM Replacement: step 5, image 2 of 3 IBM ThinkPad 600E RAM Replacement: step 5, image 3 of 3
    • Using a screwdriver, loosen but do not remove the captive screw by turning counterclockwise.
    • One 3mm PH0 screw
  6. IBM ThinkPad 600E RAM Replacement: step 6, image 1 of 3 IBM ThinkPad 600E RAM Replacement: step 6, image 2 of 3 IBM ThinkPad 600E RAM Replacement: step 6, image 3 of 3
    • Using your fingers, pry the small retention clips apart until the ram pops up.
  7. IBM ThinkPad 600E RAM Replacement: step 7, image 1 of 2 IBM ThinkPad 600E RAM Replacement: step 7, image 2 of 2
    • Using your fingers, pull straight in line with the ram to remove it.
  8. IBM ThinkPad 600E RAM Replacement: step 8, image 1 of 3 IBM ThinkPad 600E RAM Replacement: step 8, image 2 of 3 IBM ThinkPad 600E RAM Replacement: step 8, image 3 of 3
    • Repeat steps 3 and 4 if you want to remove the second ram stick.
2 other people completed this guide.
Harold Rocha
144 Reputation
1 Guide authored
USF Tampa, Team 1-4, Nance Fall 2016 Member of USF Tampa, Team 1-4, Nance Fall 2016
USFT-NANCE-F16S1G4
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 14
All Time: 1,228
