IBM ThinkPad A30 RAM Replacement
  1. IBM ThinkPad A30 RAM Replacement, Battery: step 1, image 1 of 2 IBM ThinkPad A30 RAM Replacement, Battery: step 1, image 2 of 2
    • Flip the ThinkPad over so that it is upside down.
    • Slide the highlighted tab to the left.
    • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
  2. IBM ThinkPad A30 RAM Replacement, RAM: step 2, image 1 of 2 IBM ThinkPad A30 RAM Replacement, RAM: step 2, image 2 of 2
    • Remove the two 5.3mm cover screws.
    • Gently lift the cover containing the RAM.
  3. IBM ThinkPad A30 RAM Replacement: step 3, image 1 of 1
    • Remove RAM module by pressing the two metal pieces outward with your thumbs.
  4. IBM ThinkPad A30 RAM Replacement: step 4, image 1 of 2 IBM ThinkPad A30 RAM Replacement: step 4, image 2 of 2
    • Lift the RAM module up and out, away from the yellow connector.
    • Place the RAM module away from any magnets or static electricity prone areas.
Jessica
162 Reputation
7 Guides authored
Cal Poly, Team 4-44, Amido Fall 2010 Member of Cal Poly, Team 4-44, Amido Fall 2010
CPSU-AMIDO-F10S4G44
4 Members
26 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 3,227
