IBM ThinkPad A31 Keyboard Replacement
  1. IBM ThinkPad A31 Keyboard Replacement, Battery: step 1, image 1 of 2 IBM ThinkPad A31 Keyboard Replacement, Battery: step 1, image 2 of 2
    • Flip the ThinkPad over so that it is upside down.
    • Push latch switch to the left.
    • Gently lift the battery out and away from the ThinkPad
    • You have to hold the latch to the left while you remove the battery. Simply pushing once will not unlock the battery
  2. IBM ThinkPad A31 Keyboard Replacement, Keyboard: step 2, image 1 of 3 IBM ThinkPad A31 Keyboard Replacement, Keyboard: step 2, image 2 of 3 IBM ThinkPad A31 Keyboard Replacement, Keyboard: step 2, image 3 of 3
    • The sticker is to keep the warranty on the laptop so once removed the warranty is void
    • Peel the sticker and remove the 15mm screw
    • Remove all 6 of the 16mm screws
  3. IBM ThinkPad A31 Keyboard Replacement: step 3, image 1 of 2 IBM ThinkPad A31 Keyboard Replacement: step 3, image 2 of 2
    • use a prying tool and insert it on the cracks on the sides of the keyboard and lift gently until you here a click
    • repeat this step on all sides of the keyboard until the keyboard is completely detached from the laptop
  4. IBM ThinkPad A31 Keyboard Replacement: step 4, image 1 of 3 IBM ThinkPad A31 Keyboard Replacement: step 4, image 2 of 3 IBM ThinkPad A31 Keyboard Replacement: step 4, image 3 of 3
    • Lift the keyboard and remove the keyboard ribbon cable from the laptop
2 other people completed this guide.
Matheus
128 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 12
All Time: 691
