IBM ThinkPad R40 Keyboard Keys Replacement
  1. IBM ThinkPad R40 Keyboard Keys Replacement, Disconnection: step 1, image 1 of 1
    • Make sure your laptop is off and disconnected from the power source to ensure safety for yourself.
  2. IBM ThinkPad R40 Keyboard Keys Replacement, Replacement: step 2, image 1 of 1
    Tool used on this step:
    Buy
    • Locate the key that needs replacing. Use tweezers to slowly pull the key off the keyboard. Doing this will expose the underside of the keyboard.
  3. IBM ThinkPad R40 Keyboard Keys Replacement, Set aside: step 3, image 1 of 1
    • Step 3: Set the old key aside and have the new key ready to be inserted onto the computer. The key has three parts, which you can see here.
  4. IBM ThinkPad R40 Keyboard Keys Replacement, Moving inside: step 4, image 1 of 1
    • The new key will have an empty slot where they key used to be. It contains a small rubber spring. After the rubber spring is inserted take the new key and line it up according to the color springs on the backside of the key along with the keyboard.
  5. IBM ThinkPad R40 Keyboard Keys Replacement, Lining up: step 5, image 1 of 1
    • After lining the key up, the black and white pieces will line up.
  6. IBM ThinkPad R40 Keyboard Keys Replacement, Finishing up: step 6, image 1 of 1
    • Step 6: The key should not be firmly locked into place and functioning normally.
Erin
231 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 16
All Time: 4,913
