IBM ThinkPad T30 Optical Drive Replacement
  1. IBM ThinkPad T30 Optical Drive Replacement, Battery: step 1, image 1 of 3 IBM ThinkPad T30 Optical Drive Replacement, Battery: step 1, image 2 of 3 IBM ThinkPad T30 Optical Drive Replacement, Battery: step 1, image 3 of 3
    • Make sure the ThinkPad is off and the power supply is unplugged.
    • Flip the ThinkPad upside down with the bottom facing you.
    • Slide the latch to the right into the unlock position.
    • While holding the latch in the unlock position, lift the battery out with your other hand.
  2. IBM ThinkPad T30 Optical Drive Replacement, Optical Drive: step 2, image 1 of 1
    • Locate the 4.8mm Phillips #0 screw on the far left of the ThinkPad, closest to the edge and above the battery, and unscrew it with a Phillips #0 screwdriver.
  3. IBM ThinkPad T30 Optical Drive Replacement: step 3, image 1 of 2 IBM ThinkPad T30 Optical Drive Replacement: step 3, image 2 of 2
    • On the side of the ThinkPad, locate a lock next to the optical drive. Use your fingernail to slide the lock to the right.
  4. IBM ThinkPad T30 Optical Drive Replacement: step 4, image 1 of 2 IBM ThinkPad T30 Optical Drive Replacement: step 4, image 2 of 2
    • Once it is unlocked, a small tab will pop out. Pull on the tab with your fingers.
    • The optical drive will easily slide out. Remove the optical drive.
Alex Kost
271 Reputation
5 Guides authored
Cal Poly, Team 3-20, Amido Fall 2012 Member of Cal Poly, Team 3-20, Amido Fall 2012
CPSU-AMIDO-F12S3G20
3 Members
16 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 60
All Time: 2,170
