IBM ThinkPad T30 Wireless Card Replacement
  1. IBM ThinkPad T30 Wireless Card Replacement, Battery: step 1, image 1 of 3 IBM ThinkPad T30 Wireless Card Replacement, Battery: step 1, image 2 of 3 IBM ThinkPad T30 Wireless Card Replacement, Battery: step 1, image 3 of 3
    • Make sure the ThinkPad is off and the power supply is unplugged.
    • Flip the ThinkPad upside down with the bottom facing you.
    • Slide the latch to the right into the unlock position.
    • While holding the latch in the unlock position, lift the battery out with your other hand.
  2. IBM ThinkPad T30 Wireless Card Replacement, Wireless Card: step 2, image 1 of 3 IBM ThinkPad T30 Wireless Card Replacement, Wireless Card: step 2, image 2 of 3 IBM ThinkPad T30 Wireless Card Replacement, Wireless Card: step 2, image 3 of 3
    • Focus on the panel at the center of the Thinkpad.
    • Unscrew the three 4mm Phillips #0 screws that bind the panel cover to the Thinkpad.
    • Lift the panel from the right edge and remove the panel.
  3. IBM ThinkPad T30 Wireless Card Replacement: step 3, image 1 of 3 IBM ThinkPad T30 Wireless Card Replacement: step 3, image 2 of 3 IBM ThinkPad T30 Wireless Card Replacement: step 3, image 3 of 3
    • Before removing the wireless card, identify the three wires that need to be removed.
    • The first two wires that are on the bottom right can be easily unplugged with your fingers by pulling on the white label that comes with the wire.
    • For the last wire on the center right, use a plastic opening tool to pry out the wire.
  4. IBM ThinkPad T30 Wireless Card Replacement: step 4, image 1 of 3 IBM ThinkPad T30 Wireless Card Replacement: step 4, image 2 of 3 IBM ThinkPad T30 Wireless Card Replacement: step 4, image 3 of 3
    • Use the plastic opening tool to pry the hinges on the side of the wireless card. These hinges hold the wireless card in place.
    • The wireless card will pop up at an angle, and can then be easily pulled out.
    • When reinserting a new wireless card, insert the card at the angle that it popped out. Then simply push the card down to lock it back into the hatch.
2 other people completed this guide.
Alex Kost
271 Reputation
5 Guides authored
Cal Poly, Team 3-20, Amido Fall 2012 Member of Cal Poly, Team 3-20, Amido Fall 2012
CPSU-AMIDO-F12S3G20
3 Members
16 Guides authored
1 Guide Comment
I f i take out this component will the computer act normally The computer has a car diagnostic program installed as an after thought as i wish to be normal computer Do i just remove and ever thing okay thanks Terry
Terry Dollery - Reply
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 19
All Time: 5,550
