IBM ThinkPad T42 Hard Drive Replacement
  1. IBM ThinkPad T42 Hard Drive Replacement, Battery Clips: step 1, image 1 of 1
    • Flip the laptop over so the underside is facing you, then, release the 2 clips holding the battery on.
    • Make sure the laptop is off when you do this, sudden power outages can cause data corruption.
  2. IBM ThinkPad T42 Hard Drive Replacement, Removing the Battery: step 2, image 1 of 1
    • Carefully grab the battery, then pull it straight out, not at an angle.
  3. IBM ThinkPad T42 Hard Drive Replacement, Hard Drive Screw: step 3, image 1 of 1
    • Unscrew the single screw holding the drive cage in place.
  4. IBM ThinkPad T42 Hard Drive Replacement, Sliding Drive Out: step 4, image 1 of 1
    • Pull the hard drive out with of its bay the help of pictured ridges. Carefully remove it.
    • It might help to open the display slightly.
  5. IBM ThinkPad T42 Hard Drive Replacement, Removal of HDD: step 5, image 1 of 1
    • Pull the Hard Drive out and proceed with replacement.
7 other people completed this guide.
Austin Kidd
317 Reputation
3 Guides authored
Cal Poly, Team 29-76, Johann Spring 2010 Member of Cal Poly, Team 29-76, Johann Spring 2010
CPSU-JOHANN-S10S29G76
4 Members
35 Guides authored
One Comment
Excelente guía. Gracias
Luis Aguilar - Reply
Past 24 Hours: 0
Past 7 Days: 18
Past 30 Days: 92
All Time: 20,906
