IBM ThinkPad T42 RAM Replacement
  1. IBM ThinkPad T42 RAM Replacement, Battery Clips: step 1, image 1 of 1
    • Flip the laptop over so the underside is facing you, then, release the 2 clips holding the battery on.
    • Make sure the laptop is off when you do this, sudden power outages can cause data corruption.
  2. IBM ThinkPad T42 RAM Replacement, Removing the Battery: step 2, image 1 of 1
    • Carefully grab the battery, then pull it straight out, not at an angle.
  3. IBM ThinkPad T42 RAM Replacement, RAM: step 3, image 1 of 1
    • Unscrew the pictured screwed holding the memory cover in place.
  4. IBM ThinkPad T42 RAM Replacement: step 4, image 1 of 1
    • Pry the cover open carefully (flathead screwdriver might help)
    • To remove the RAM memory stick, push both metal pieces holding it in place outwards, and the stick will pop up.
    • Pull the stick out carefully.
    • In order to replace the other stick, refer to the keyboard replacement tutorial. The other SODIMM is easily accessible with the keyboard removed.
7 other people completed this guide.
Kevin Rehm
472 Reputation
4 Guides authored
Cal Poly, Team 29-76, Johann Spring 2010 Member of Cal Poly, Team 29-76, Johann Spring 2010
CPSU-JOHANN-S10S29G76
4 Members
37 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 7,269
