IBM ThinkPad X41 Keyboard Replacement
  1. IBM ThinkPad X41 Keyboard Replacement, Keyboard: step 1, image 1 of 3 IBM ThinkPad X41 Keyboard Replacement, Keyboard: step 1, image 2 of 3 IBM ThinkPad X41 Keyboard Replacement, Keyboard: step 1, image 3 of 3
    • Slide outward to unlock and lift battery up to remove.
    • Remove battery before keyboard to avoid damage to battery.
  2. IBM ThinkPad X41 Keyboard Replacement: step 2, image 1 of 1
    • With a Phillips PH000 to remove all six 6 mm screws identified for the keyboard as shown.
  3. IBM ThinkPad X41 Keyboard Replacement: step 3, image 1 of 3 IBM ThinkPad X41 Keyboard Replacement: step 3, image 2 of 3 IBM ThinkPad X41 Keyboard Replacement: step 3, image 3 of 3
    • Flip the laptop over once more returning it to its upright position and open laptop .
  4. IBM ThinkPad X41 Keyboard Replacement: step 4, image 1 of 2 IBM ThinkPad X41 Keyboard Replacement: step 4, image 2 of 2
    • Using your left hand, place thumb on the upper part of the keyboard and place your other thumb on the bottom part of the keyboard.
    • Push firmly upward with both thumbs. This will detach keyboard from base.
    • Be cautious when lifting as there is an orange connection cable still attached to the bottom side.
  5. IBM ThinkPad X41 Keyboard Replacement: step 5, image 1 of 2 IBM ThinkPad X41 Keyboard Replacement: step 5, image 2 of 2
    • Detach the connection to the motherboard by first sliding it towards you, then pulling upward away from your body.
    • This step's directions are based on the angle shown .
  6. IBM ThinkPad X41 Keyboard Replacement: step 6, image 1 of 1
    • Lift the entire keyboard off the laptop.
Lisbeth Cisneros
131 Reputation
1 Guide authored
CSU Fullerton, Team 2-4, Bruce Fall 2016 Member of CSU Fullerton, Team 2-4, Bruce Fall 2016
CSUF-BRUCE-F16S2G4
4 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 899
