IBM Thinkpad T60 Hard Drive Replacement
  1. IBM Thinkpad T60 Hard Drive Replacement, Hard Drive: step 1, image 1 of 1
    • Turn the Thinkpad over so you can see the back.
    • Locate this screw in the bottom left-hand corner.
  2. IBM Thinkpad T60 Hard Drive Replacement: step 2, image 1 of 1
    • Using a #0 Phillips screwdriver, remove the 17.0 mm screw.
  3. IBM Thinkpad T60 Hard Drive Replacement: step 3, image 1 of 1
    • Carefully remove the plastic piece covering the hard drive port by pulling perpendicular to the side of the laptop.
  4. IBM Thinkpad T60 Hard Drive Replacement: step 4, image 1 of 2 IBM Thinkpad T60 Hard Drive Replacement: step 4, image 2 of 2
    • Use a small screwdriver to locate the black ribbon.
    • With the screwdriver, pull the black tab out of the slot.
  5. IBM Thinkpad T60 Hard Drive Replacement: step 5, image 1 of 2 IBM Thinkpad T60 Hard Drive Replacement: step 5, image 2 of 2
    • Pull gently on the black ribbon and the metal tray carrying the hard drive will slide out.
  6. IBM Thinkpad T60 Hard Drive Replacement: step 6, image 1 of 1
    • Remove the black plastic coverings on either side of the hard drive.
    • There is not a hard drive in this example, but the process is the same regardless.
9 other people completed this guide.
Cody Kratochvil
560 Reputation
5 Guides authored
Cal Poly, Team 7-9, Maness Winter 2013 Member of Cal Poly, Team 7-9, Maness Winter 2013
CPSU-MANESS-W13S7G9
4 Members
16 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 64
All Time: 11,070
