IBM Thinkpad T61 Trackpad Replacement
  1. IBM Thinkpad T61 Trackpad Replacement, Trackpad: step 1, image 1 of 1
    • Flip your computer over and remove the four indicated screws with the Phillips #1 screwdriver.
  2. IBM Thinkpad T61 Trackpad Replacement: step 2, image 1 of 1
    • With the screws removed, the trackpad panel should lift as shown. Gently lift so the inside is visible.
  3. IBM Thinkpad T61 Trackpad Replacement: step 3, image 1 of 2 IBM Thinkpad T61 Trackpad Replacement: step 3, image 2 of 2
    • Gently remove the white plug to disconnect the trackpad panel from the bottom of the computer.
    • Use the screwdriver to remove the four screws from the trackpad. Two of the screws are located just under the plastic.
  4. IBM Thinkpad T61 Trackpad Replacement: step 4, image 1 of 3 IBM Thinkpad T61 Trackpad Replacement: step 4, image 2 of 3 IBM Thinkpad T61 Trackpad Replacement: step 4, image 3 of 3
    • Separate the trackpad with the bottom mouse buttons from the trackpad panel.
  5. IBM Thinkpad T61 Trackpad Replacement: step 5, image 1 of 1
    • Align the new trackpad so the screw holes line up with their insertion points. Replace the screws with the screwdriver.
  6. IBM Thinkpad T61 Trackpad Replacement: step 6, image 1 of 1
    • Reinsert the white plug.
  7. IBM Thinkpad T61 Trackpad Replacement: step 7, image 1 of 2 IBM Thinkpad T61 Trackpad Replacement: step 7, image 2 of 2
    • Replace the trackpad panel.
    • Use the screwdriver to replace the screws, refastening the trackpad panel to the computer.
Replace the battery and plug in your computer. Test out your new trackpad!
7 other people completed this guide.
Raymond Lawton
263 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 26
All Time: 2,080
