IQ America VD-8810L Motherboard Replacement
  1. IQ America VD-8810L Motherboard Replacement, Motherboard: step 1, image 1 of 3 IQ America VD-8810L Motherboard Replacement, Motherboard: step 1, image 2 of 3 IQ America VD-8810L Motherboard Replacement, Motherboard: step 1, image 3 of 3
    • Wedge the spudger into the slot of the panel on the bottom of the device.
    • Rotate out the panel to reveal the screw holding the device together.
  2. IQ America VD-8810L Motherboard Replacement: step 2, image 1 of 2 IQ America VD-8810L Motherboard Replacement: step 2, image 2 of 2
    • Use the Phillips head screwdriver to remove the screw.
    • Separate the Top and bottom halves of the device.
  3. IQ America VD-8810L Motherboard Replacement: step 3, image 1 of 3 IQ America VD-8810L Motherboard Replacement: step 3, image 2 of 3 IQ America VD-8810L Motherboard Replacement: step 3, image 3 of 3
    • Remove batteries from the battery slot.
    • Unscrew the two Phillips head screws in the center of the battery slot.
    • Unscrew the remaining two screws at the bottom of the unit using the 3.0 triangle head screwdriver.
  4. IQ America VD-8810L Motherboard Replacement: step 4, image 1 of 1
    • Use the spudger to separate the top and bottom halves of the screen.
  5. IQ America VD-8810L Motherboard Replacement: step 5, image 1 of 1
    • Disconnect the wires from the green motherboard to the bottom half by pulling apart the connecting pins.
  6. IQ America VD-8810L Motherboard Replacement: step 6, image 1 of 3 IQ America VD-8810L Motherboard Replacement: step 6, image 2 of 3 IQ America VD-8810L Motherboard Replacement: step 6, image 3 of 3
    • Unscrew all 3 Phillips head screws on the outside edges of the motherboard.
  7. IQ America VD-8810L Motherboard Replacement: step 7, image 1 of 1
    • Carefully remove the microphone from the casing by pulling away from the device.
  8. IQ America VD-8810L Motherboard Replacement: step 8, image 1 of 2 IQ America VD-8810L Motherboard Replacement: step 8, image 2 of 2
    • Gently lift the motherboard from the casing to reveal the speaker.
    • Unscrew the two Phillips head screws that hold the speaker in place.
  9. IQ America VD-8810L Motherboard Replacement: step 9, image 1 of 1
    • Refer to this guide to desolder the speaker from the motherboard.
Jackey Lau
301 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 252
