Ideapad 3-17IAU7 Memory Replacement
  1. Ideapad 3-17IAU7 Memory Replacement, Removing Bottom Case: step 1, image 1 of 1
    • Please turn off the device before opening the device
    • Remove the ten screws as shown in picture
    • The four bottom screws are different length for the other screws! (Blue Circle)
    • Remove the bottom case using a guitar pick
  2. Ideapad 3-17IAU7 Memory Replacement, Removing the memory module: step 2, image 1 of 2 Ideapad 3-17IAU7 Memory Replacement, Removing the memory module: step 2, image 2 of 2
    • Remove the cable buy pushing the connector using the spudger (Red Circle)
    • Remove the Memory protective by using a pry tool (yellow rectangle)
    • After removing the memory protective push the silver tabs using a spudger (blue rectangle)
    • Remove the memory module.
  3. Ideapad 3-17IAU7 Memory Replacement, Installing Memory module: step 3, image 1 of 1
    • Insert the new module according to the pin array
    • Push gently on the module until the two tabs are locked. (Locking the module)
Attached Documents
Ilia Tocheny
1,616 Reputation
9 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 12
All Time: 170
