Ideapad 3-17IAU7 Solid State Drive Replacement
  1. Ideapad 3-17IAU7 Solid State Drive Replacement, Removing Bottom Case: step 1, image 1 of 1
    • Please turn off the device before opening the device
    • Remove the ten screws as shown in picture
    • The four bottom screws are different length for the other screws! (Blue Circle)
    • Remove the bottom case using a guitar pick
  2. Ideapad 3-17IAU7 Solid State Drive Replacement, Removing SSD: step 2, image 1 of 1
    • Using the screw driver remove the screw (Red Circle)
    • The device will be lifted remove it by pulling the device.
  3. Ideapad 3-17IAU7 Solid State Drive Replacement, Adding new SSD: step 3, image 1 of 1
    • Insert the new SSD according the pins on the motherboard.
    • Push gently on the SSD and screw it using the screw which was removed
Ilia Tocheny
1,616 Reputation
9 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 126
