Imation Superdisk USB Drive Disc Drive Casing Replacement
  1. Imation Superdisk USB Drive Disc Drive Casing Replacement, Plastic Housing: step 1, image 1 of 2 Imation Superdisk USB Drive Disc Drive Casing Replacement, Plastic Housing: step 1, image 2 of 2
    • Flip the device over so the bottom is facing up.
    • You will know it is the bottom because there will be six silver screws visible.
  2. Imation Superdisk USB Drive Disc Drive Casing Replacement: step 2, image 1 of 2 Imation Superdisk USB Drive Disc Drive Casing Replacement: step 2, image 2 of 2
    • Remove the USB converter device by gently pulling it out.
    • Do not pull the converter device out by the cord.
  3. Imation Superdisk USB Drive Disc Drive Casing Replacement: step 3, image 1 of 2 Imation Superdisk USB Drive Disc Drive Casing Replacement: step 3, image 2 of 2
    • Remove the six silver screws using a small Phillips head screwdriver.
  4. Imation Superdisk USB Drive Disc Drive Casing Replacement: step 4, image 1 of 2 Imation Superdisk USB Drive Disc Drive Casing Replacement: step 4, image 2 of 2
    • Slide the bottom plastic panel of the shell down so it is free of the end cap and the top panel.
    • Lift panel free of device.
  5. Imation Superdisk USB Drive Disc Drive Casing Replacement: step 5, image 1 of 2 Imation Superdisk USB Drive Disc Drive Casing Replacement: step 5, image 2 of 2
    • Identify the end cap by noting the label "SuperDisk Drive" above where you would insert a floppy disk.
    • Remove the plastic end cap by sliding it forward, freeing from the rest of the device.
  6. Imation Superdisk USB Drive Disc Drive Casing Replacement: step 6, image 1 of 2 Imation Superdisk USB Drive Disc Drive Casing Replacement: step 6, image 2 of 2
    • Slide the metal housing out of the plastic shell.
  7. Imation Superdisk USB Drive Disc Drive Casing Replacement, Metal Casing: step 7, image 1 of 2 Imation Superdisk USB Drive Disc Drive Casing Replacement, Metal Casing: step 7, image 2 of 2
    • Slide metal panel out of the metal casing.
  8. Imation Superdisk USB Drive Disc Drive Casing Replacement: step 8, image 1 of 2 Imation Superdisk USB Drive Disc Drive Casing Replacement: step 8, image 2 of 2
    • Slide disk drive out of metal casing.
  9. Imation Superdisk USB Drive Disc Drive Casing Replacement, Daughter Board: step 9, image 1 of 1
    • Flip the disk drive over so the the plug on the daughter board is visible.
  10. Imation Superdisk USB Drive Disc Drive Casing Replacement: step 10, image 1 of 2 Imation Superdisk USB Drive Disc Drive Casing Replacement: step 10, image 2 of 2
    • Using an iPod opener put pressure on the white plug and pull backwards until the daughter board unplugs from the main unit.
  11. Imation Superdisk USB Drive Disc Drive Casing Replacement: step 11, image 1 of 2 Imation Superdisk USB Drive Disc Drive Casing Replacement: step 11, image 2 of 2
    • Gently pull on the daughter board until it separates from the device.
  12. Imation Superdisk USB Drive Disc Drive Casing Replacement, Disc Drive Casing: step 12, image 1 of 2 Imation Superdisk USB Drive Disc Drive Casing Replacement, Disc Drive Casing: step 12, image 2 of 2
    • Place a plastic spudger in between the disk drive and its metal casing. Use the spudger as a lever the until the metal casing detaches from the disk drive.
    • You may have to use the plastic spudger in several spots along the metal casing.
  13. Imation Superdisk USB Drive Disc Drive Casing Replacement: step 13, image 1 of 1
    • lift the disk drive completely out of the metal casing and set it aside.
Caitlin Horwatt
137 Reputation
2 Guides authored
Ohio State, Team 1-2, Buehl Spring 2014 Member of Ohio State, Team 1-2, Buehl Spring 2014
OSU-BUEHL-S14S1G2
4 Members
14 Guides authored
1 Guide Comment
Does anyone know if the MAC USB version works on modern PCs?
davidpaulpeterson - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 8
All Time: 782
