Lite-On LightScribe SHM-165H6S Faceplate/Eject button Replacement
  1. Lite-On LightScribe SHM-165H6S Faceplate/Eject button Replacement, Faceplate/Eject button: step 1, image 1 of 2 Lite-On LightScribe SHM-165H6S Faceplate/Eject button Replacement, Faceplate/Eject button: step 1, image 2 of 2
    • Insert an open paper clip into small hole on left side of faceplate.
    • The tray should click open, use your hands to gently extend it fully.
  2. Lite-On LightScribe SHM-165H6S Faceplate/Eject button Replacement: step 2, image 1 of 3 Lite-On LightScribe SHM-165H6S Faceplate/Eject button Replacement: step 2, image 2 of 3 Lite-On LightScribe SHM-165H6S Faceplate/Eject button Replacement: step 2, image 3 of 3
    • Push in black tabs on left, right and bottom of outer chassis to unhook faceplate.
  3. Lite-On LightScribe SHM-165H6S Faceplate/Eject button Replacement: step 3, image 1 of 1
    • Pull face plate away from main chassis.
  4. Lite-On LightScribe SHM-165H6S Faceplate/Eject button Replacement: step 4, image 1 of 3 Lite-On LightScribe SHM-165H6S Faceplate/Eject button Replacement: step 4, image 2 of 3 Lite-On LightScribe SHM-165H6S Faceplate/Eject button Replacement: step 4, image 3 of 3
    • Locate the two tabs on the underside of the tray cover.
    • Pry the tabs loose and remove cover.
  5. Lite-On LightScribe SHM-165H6S Faceplate/Eject button Replacement: step 5, image 1 of 1
    • Remove and replace faceplate.
aaa
171 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 2,179
