Impression i7 Battery Replacement
  1. Impression i7 Battery Replacement, Battery: step 1, image 1 of 1
    • Wedge the plastic opening tool into the seam nearest to the screen surface and begin to pry off the back of the device.
  2. Impression i7 Battery Replacement: step 2, image 1 of 1
    • Move the plastic opening tool along the perimeter of the device, loosening the entire back as you go.
  3. Impression i7 Battery Replacement: step 3, image 1 of 1
    • After the entire perimeter has been pried, remove the back of the device.
    • Be careful not to disconnect the speaker and microphone cables attached to the back of the tablet.
  4. Impression i7 Battery Replacement: step 4, image 1 of 2 Impression i7 Battery Replacement: step 4, image 2 of 2
    • Remove the transparent, orange tape from the edge of the battery.
    • Pry the battery off, using the plastic opening tool.
  5. Impression i7 Battery Replacement: step 5, image 1 of 1
    • Desolder the positive and negative leads.
  6. Impression i7 Battery Replacement: step 6, image 1 of 2 Impression i7 Battery Replacement: step 6, image 2 of 2
    • Pull the battery away from the adhesive.
    • Peel the gray tape from the top of the battery.
2 other people completed this guide.
Cole Beaver
417 Reputation
3 Guides authored
IUPUI, Team S1-G5, Baechle Fall 2018 Member of IUPUI, Team S1-G5, Baechle Fall 2018
IUPUI-BAECHLE-F18S1G5
3 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 28
All Time: 332
