In-Ground Pool Filter Replacement
  1. In-Ground Pool Filter Replacement, Filter: step 1, image 1 of 2 In-Ground Pool Filter Replacement, Filter: step 1, image 2 of 2
    • Make sure the pool pump switch is off.
  2. In-Ground Pool Filter Replacement: step 2, image 1 of 3 In-Ground Pool Filter Replacement: step 2, image 2 of 3 In-Ground Pool Filter Replacement: step 2, image 3 of 3
    • Unscrew the metal ring bracket that is on the filter housing in order to remove the top half of the filter housing (lid). Turn the handle in a counter-clock wise motion until it is completely loose and the screw can be removed.
  3. In-Ground Pool Filter Replacement: step 3, image 1 of 3 In-Ground Pool Filter Replacement: step 3, image 2 of 3 In-Ground Pool Filter Replacement: step 3, image 3 of 3
    • Take the metal ring bracket off.
  4. In-Ground Pool Filter Replacement: step 4, image 1 of 2 In-Ground Pool Filter Replacement: step 4, image 2 of 2
    • Remove the top half of the filter housing.
  5. In-Ground Pool Filter Replacement: step 5, image 1 of 3 In-Ground Pool Filter Replacement: step 5, image 2 of 3 In-Ground Pool Filter Replacement: step 5, image 3 of 3
    • Remove the O-ring.
  6. In-Ground Pool Filter Replacement: step 6, image 1 of 3 In-Ground Pool Filter Replacement: step 6, image 2 of 3 In-Ground Pool Filter Replacement: step 6, image 3 of 3
    • Unscrew the filter cap in a counter clock wise motion until it comes off.
  7. In-Ground Pool Filter Replacement: step 7, image 1 of 3 In-Ground Pool Filter Replacement: step 7, image 2 of 3 In-Ground Pool Filter Replacement: step 7, image 3 of 3
    • Take the pool filter out and place on the ground. Put the new filter in and to put it all back together you can simply follow these directions in reverse order.
    • While the filter housing is apart, you should inspect the O-ring to determine if it has any cracks or tears. If so, replace it with a new O-ring. If it still appears to be in decent condition, then continue to use it and apply a little lube. NEVER use Vaseline or any other petroleum-based lubricant on pool parts. Look for silicone-based lubes.
Every pool has different size filters. This guide is a general reference of how to replace a filter and return the filter back to the pump. To reassemble your device, follow these instructions in reverse order.
4 other people completed this guide.
Benjamin Goodman
232 Reputation
1 Guide authored
1 Guide Comment
Which model is this?
Osvaldo walle - Reply
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 19
All Time: 1,110
