InFocus IN3104 Cooling Fan Replacement
  1. InFocus IN3104 Cooling Fan Replacement, Top Cover: step 1, image 1 of 3 InFocus IN3104 Cooling Fan Replacement, Top Cover: step 1, image 2 of 3 InFocus IN3104 Cooling Fan Replacement, Top Cover: step 1, image 3 of 3
    • Turn the projector so that the lens is facing you.
    • On the left side of the projector, there is a screw and a knob inside of the small grate.
    • Use a Phillips #1 screwdriver to remove the 6 mm screw that secures top cover.
    • Remove the service cover.
  2. InFocus IN3104 Cooling Fan Replacement: step 2, image 1 of 3 InFocus IN3104 Cooling Fan Replacement: step 2, image 2 of 3 InFocus IN3104 Cooling Fan Replacement: step 2, image 3 of 3
    • Use a Phillips #1 screwdriver to remove the seven 6 mm screws.
    • Use a Phillips #1 screwdriver to remove the two 5 mm screws.
    • Remove the top cover.
    • Do not pull the cover too hard. It may damage the wire that is connected to the motherboard.
  3. InFocus IN3104 Cooling Fan Replacement, InFocus IN3104 Metal Cover Disassembly: step 3, image 1 of 2 InFocus IN3104 Cooling Fan Replacement, InFocus IN3104 Metal Cover Disassembly: step 3, image 2 of 2
    • Use a Phillips #1 screwdriver to remove the nine 6 mm screws.
    • Lift up the metal cover and set it aside to reveal the motherboard.
  4. InFocus IN3104 Cooling Fan Replacement: step 4, image 1 of 3 InFocus IN3104 Cooling Fan Replacement: step 4, image 2 of 3 InFocus IN3104 Cooling Fan Replacement: step 4, image 3 of 3
    • Carefully pry up the black plastic locking bar of the ZIF connector on the motherboard with a plastic spudger.
    • Pull out the blue-tipped, white ribbon cable from the connector.
    • Remove the metal cover.
  5. InFocus IN3104 Cooling Fan Replacement, Cooling Fan: step 5, image 1 of 2 InFocus IN3104 Cooling Fan Replacement, Cooling Fan: step 5, image 2 of 2
    • Use a Phillips #1 screwdriver to remove the three 6 mm screws on the metal cover beside the lamp.
    • The screws are in a tight location, so you may need a thin screwdriver or an extension to remove them.
  6. InFocus IN3104 Cooling Fan Replacement: step 6, image 1 of 3 InFocus IN3104 Cooling Fan Replacement: step 6, image 2 of 3 InFocus IN3104 Cooling Fan Replacement: step 6, image 3 of 3
    • Unplug the yellow, red, and black colored cable bundle from the motherboard.
    • Remove the cooling fan from the device by lifting it out.
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 14
All Time: 481
