InFocus IN3104 Filter Replacement
  1. InFocus IN3104 Filter Replacement, Top Cover: step 1, image 1 of 3 InFocus IN3104 Filter Replacement, Top Cover: step 1, image 2 of 3 InFocus IN3104 Filter Replacement, Top Cover: step 1, image 3 of 3
    • Turn the projector so that the lens is facing you.
    • On the left side of the projector, there is a screw and a knob inside of the small grate.
    • Use a Phillips #1 screwdriver to remove the 6 mm screw that secures top cover.
    • Remove the service cover.
  2. InFocus IN3104 Filter Replacement: step 2, image 1 of 3 InFocus IN3104 Filter Replacement: step 2, image 2 of 3 InFocus IN3104 Filter Replacement: step 2, image 3 of 3
    • Use a Phillips #1 screwdriver to remove the seven 6 mm screws.
    • Use a Phillips #1 screwdriver to remove the two 5 mm screws.
    • Remove the top cover.
    • Do not pull the cover too hard. It may damage the wire that is connected to the motherboard.
  3. InFocus IN3104 Filter Replacement, Filter: step 3, image 1 of 3 InFocus IN3104 Filter Replacement, Filter: step 3, image 2 of 3 InFocus IN3104 Filter Replacement, Filter: step 3, image 3 of 3
    • Use a Phillips # 1 screw driver to remove the 6 mm screw that secures the filter.
    • Once the screw is removed, remove the filter by pulling it straight out.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 26
All Time: 455
