InFocus IN3114 LED Touch Board Replacement
  1. InFocus IN3114 LED Touch Board Replacement, Top Plate: step 1, image 1 of 2 InFocus IN3114 LED Touch Board Replacement, Top Plate: step 1, image 2 of 2
    • Use a Phillips #1 screwdriver to remove the 1.2 cm Phillips-head screw from each side of the projector.
  2. InFocus IN3114 LED Touch Board Replacement: step 2, image 1 of 3 InFocus IN3114 LED Touch Board Replacement: step 2, image 2 of 3 InFocus IN3114 LED Touch Board Replacement: step 2, image 3 of 3
    • Use your hands to slide the top plate off of the projector.
    • Lift and remove the plate.
  3. InFocus IN3114 LED Touch Board Replacement, LED Touch Board: step 3, image 1 of 2 InFocus IN3114 LED Touch Board Replacement, LED Touch Board: step 3, image 2 of 2
    • Use the opening tool to lift the control panel cover.
    • Remove the cover.
  4. InFocus IN3114 LED Touch Board Replacement: step 4, image 1 of 3 InFocus IN3114 LED Touch Board Replacement: step 4, image 2 of 3 InFocus IN3114 LED Touch Board Replacement: step 4, image 3 of 3
Kevin Li
85 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 252
