InFocus IN3114 Lamp Replacement
  1. InFocus IN3114 Lamp Replacement, Top Plate: step 1, image 1 of 2 InFocus IN3114 Lamp Replacement, Top Plate: step 1, image 2 of 2
    • Use a Phillips #1 screwdriver to remove the 1.2 cm Phillips-head screw from each side of the projector.
  2. InFocus IN3114 Lamp Replacement: step 2, image 1 of 3 InFocus IN3114 Lamp Replacement: step 2, image 2 of 3 InFocus IN3114 Lamp Replacement: step 2, image 3 of 3
    • Use your hands to slide the top plate off of the projector.
    • Lift and remove the plate.
  3. InFocus IN3114 Lamp Replacement, Lamp: step 3, image 1 of 1
    • Use a Phillips #1 screwdriver to unscrew the two 9 mm screws on the top of the lamp housing unit.
    • Screws will not come all the way out. It is best to just loosen them as much as possible.
  4. InFocus IN3114 Lamp Replacement: step 4, image 1 of 1
    • Use your hands to pull up on the silver handle and remove the lamp housing unit.
  5. InFocus IN3114 Lamp Replacement: step 5, image 1 of 2 InFocus IN3114 Lamp Replacement: step 5, image 2 of 2
    • Once the lamp housing is removed flip it over where silver pull tab is face down.
    • Use a Phillips #00 screwdriver to remove the 5 mm screw from the right side of the lamp housing unit.
    • Use a Phillips #00 screwdriver to remove the two 5 mm screws from the top of the unit.
  6. InFocus IN3114 Lamp Replacement: step 6, image 1 of 1
    • Use hands to pull off the black unit cover.
  7. InFocus IN3114 Lamp Replacement: step 7, image 1 of 2 InFocus IN3114 Lamp Replacement: step 7, image 2 of 2
    • Once the cover is removed, flip the housing unit so the bulb is face down.
    • Remove the four 4 mm screws with a Phillips #00 screwdriver.
  8. InFocus IN3114 Lamp Replacement: step 8, image 1 of 2 InFocus IN3114 Lamp Replacement: step 8, image 2 of 2
    • Use hands to pull out the bulb and silver cover.
    • Gently pull on the two wires that connect the bulb to its housing to disconnect them.
  9. InFocus IN3114 Lamp Replacement: step 9, image 1 of 2 InFocus IN3114 Lamp Replacement: step 9, image 2 of 2
    • Once wires are disconnected, Remove the bulb from the silver cover and replace.
Lily Calvert
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 18
All Time: 757
