InFocus IN35W Daughterboard Replacement
  1. InFocus IN35W Daughterboard Replacement, Top Plate: step 1, image 1 of 3 InFocus IN35W Daughterboard Replacement, Top Plate: step 1, image 2 of 3 InFocus IN35W Daughterboard Replacement, Top Plate: step 1, image 3 of 3
    • Use the plastic opening tool to remove the front plastic casing surrounding the lens.
    • Pry apart the clips securing the top and bottom of the device using the plastic opening tool.
  2. InFocus IN35W Daughterboard Replacement: step 2, image 1 of 2 InFocus IN35W Daughterboard Replacement: step 2, image 2 of 2
    • Pull the top piece up.
    • The two gray ventilation grates will slip off the device.
  3. InFocus IN35W Daughterboard Replacement: step 3, image 1 of 2 InFocus IN35W Daughterboard Replacement: step 3, image 2 of 2
    • Detach the white speaker wire that connects the motherboard to the top piece.
    • Remove the top cover from the device.
  4. InFocus IN35W Daughterboard Replacement, Daughterboard: step 4, image 1 of 2 InFocus IN35W Daughterboard Replacement, Daughterboard: step 4, image 2 of 2
    • Remove one 7 mm screw from the silver fastening plate using a Torx T9 screwdriver.
  5. InFocus IN35W Daughterboard Replacement: step 5, image 1 of 2 InFocus IN35W Daughterboard Replacement: step 5, image 2 of 2
    • Remove eight 7 mm screws from the daughterboard using a Torx T9 screwdriver.
  6. InFocus IN35W Daughterboard Replacement: step 6, image 1 of 2 InFocus IN35W Daughterboard Replacement: step 6, image 2 of 2
    • Disconnect the red and black bundled cable from its connector on the daughterboard.
    • Grab the daughterboard by the sides and carefully lift it out from the top plate.
Grace Hubert
608 Reputation
5 Guides authored
UMass Dartmouth, Team 1-2, Simcock Fall 2021 Member of UMass Dartmouth, Team 1-2, Simcock Fall 2021
UMASSD-SIMCOCK-F21S1G2
4 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 16
All Time: 153
