InFocus IN35W Lamp Replacement
  1. InFocus IN35W Lamp Replacement, Lamp: step 1, image 1 of 2 InFocus IN35W Lamp Replacement, Lamp: step 1, image 2 of 2
    • Flip the projector on its backside and lay it on a flat surface.
    • Remove the lamp door gently with your hands or a plastic opening tool.
  2. InFocus IN35W Lamp Replacement: step 2, image 1 of 2 InFocus IN35W Lamp Replacement: step 2, image 2 of 2
    • Loosen the slotted screw with a flathead screwdriver (3.0).
  3. InFocus IN35W Lamp Replacement: step 3, image 1 of 2 InFocus IN35W Lamp Replacement: step 3, image 2 of 2
    • Disconnect the lamp connector wire from the projector body.
    • This part takes some force, but try to pull as carefully as possible to avoid breakage.
  4. InFocus IN35W Lamp Replacement: step 4, image 1 of 1
    • Carefully remove the lamp from its socket.
Grace Hubert
608 Reputation
5 Guides authored
UMass Dartmouth, Team 1-2, Simcock Fall 2021 Member of UMass Dartmouth, Team 1-2, Simcock Fall 2021
UMASSD-SIMCOCK-F21S1G2
4 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 8
All Time: 231
