InFocus LP435Z DLP Board Replacement
Introduction
Go to step 1The Digital Light Processing (DLP) board is what converts the video input from an outside source (like a computer) into a format the projector can display. If this board is damaged or faulty, a whole host of image projection issues can occur that will not be fixed by cleaning the lens or replacing the lamp.
Tools
Show more…
Place the projector on its back (buttons down) with the lens facing away from you.
Remove the two 84mm screws in the upper left and right corners of the projector using the Phillips #2 screwdriver.
Remove the remaining three 8.5mm screws using the Phillips #1 screwdriver.
Flip the projector over and turn around so that the lens faces you.
Twist the gray zoom adjustment ring clockwise and extend the lens all the way out, and then slide the zoom adjustment ring all the way towards the end of the lens as far as it will go.
Slide the front case plate towards the loosened zoom adjustment ring, until the top plate of the projector is freed from underneath the lip of the front case plate.
3 other people completed this guide.
One Comment
I Andrew
Recently I bought an INFOCUS LP435Z, it was with the inverted image, when I wanted to use the buttons to enter the menu, to modify the image inversion, none of the buttons reacted.
You will have an idea of what is due and how to solve it? Could it be that with the option of active blocking? I do not have the unlock key, how could I check it?
Thank you very much for your answer.
Regards
