InFocus LP540 Projector Lamp Replacement
  1. InFocus LP540 Projector Lamp Replacement, Lamp: step 1, image 1 of 2 InFocus LP540 Projector Lamp Replacement, Lamp: step 1, image 2 of 2
    • Place the projector on its back with the control buttons facing down.
    • Remove the black 7mm screw on the external case with a Phillips 2 screwdriver.
  2. InFocus LP540 Projector Lamp Replacement: step 2, image 1 of 1
    • Use the plastic flat-head to remove the lamp lid.
  3. InFocus LP540 Projector Lamp Replacement: step 3, image 1 of 2 InFocus LP540 Projector Lamp Replacement: step 3, image 2 of 2
    • Remove the 7mm screw near the bottom center with a Philips 2 screwdriver head.
    • Loosen but do not remove the 7mm screw near the upper right corner with the Phillips 2 screwdriver head.
  4. InFocus LP540 Projector Lamp Replacement: step 4, image 1 of 3 InFocus LP540 Projector Lamp Replacement: step 4, image 2 of 3 InFocus LP540 Projector Lamp Replacement: step 4, image 3 of 3
    • Grab the silver handle.
    • Unhook the handle so it can move freely.
    • Pull the handle straight up until the lamp is completely removed from projector.
Jorge L Navarro
533 Reputation
5 Guides authored
Cal Poly, Team 13-17, Regan Winter 2014 Member of Cal Poly, Team 13-17, Regan Winter 2014
CPSU-REGAN-W14S13G17
6 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 3,244
