InFocus LP540 Projector Lens Replacement
  1. InFocus LP540 Projector Lens Replacement, Main Board: step 1, image 1 of 3 InFocus LP540 Projector Lens Replacement, Main Board: step 1, image 2 of 3 InFocus LP540 Projector Lens Replacement, Main Board: step 1, image 3 of 3
    • Flip the projector right-side up and turn it so that the back ports are facing you.
    • Remove the 7 mm metallic screws using the flat-head screwdriver.
    • Using the T10 Torx screwdriver, remove the two black 10 mm screws located at the center of the back panel.
  2. InFocus LP540 Projector Lens Replacement: step 2, image 1 of 2 InFocus LP540 Projector Lens Replacement: step 2, image 2 of 2
    • Flip the projector over.
    • Use the T10 Torx screwdriver head to remove the two 77mm screws located nearest to the back panel ports.
    • Remove the two 10mm screws located near the lens side with the T10 Torx screwdriver head.
    • Flip the projector back over.
    • Lift up the main lid cautiously to avoid ripping the electrical ribbons.
  3. InFocus LP540 Projector Lens Replacement: step 3, image 1 of 3 InFocus LP540 Projector Lens Replacement: step 3, image 2 of 3 InFocus LP540 Projector Lens Replacement: step 3, image 3 of 3
    • Unplug the speaker wire from the circuit board by simultaneously squeezing the sides and pulling.
    • Pull on the brown tabs located at the sides of the white plastic ribbon holder and pull the ribbon out.
    • Remove the top cover.
  4. InFocus LP540 Projector Lens Replacement: step 4, image 1 of 2 InFocus LP540 Projector Lens Replacement: step 4, image 2 of 2
    • Hold down the release tabs to remove the cables from the white tabs.
  5. InFocus LP540 Projector Lens Replacement: step 5, image 1 of 3 InFocus LP540 Projector Lens Replacement: step 5, image 2 of 3 InFocus LP540 Projector Lens Replacement: step 5, image 3 of 3
    • Use the T10 Torx screwdriver to remove the five 5mm screws located throughout the motherboard.
    • Pull up the five metal tabs located at the rear of the projector.
    • Do not pull up on the metal tabs too hard or too fast because they can break easily.
  6. InFocus LP540 Projector Lens Replacement: step 6, image 1 of 3 InFocus LP540 Projector Lens Replacement: step 6, image 2 of 3 InFocus LP540 Projector Lens Replacement: step 6, image 3 of 3
    • Remove the three gold ribbons by flipping up the black taps that hold the ribbon in place.
    • Pull the ribbons out carefully and place them under the main board.
    • Carefully lift the entire main board up.
  7. InFocus LP540 Projector Lens Replacement, Lens: step 7, image 1 of 2 InFocus LP540 Projector Lens Replacement, Lens: step 7, image 2 of 2
    • Remove the two 10 mm screws using the Philips 0 screwdriver head.
  8. InFocus LP540 Projector Lens Replacement: step 8, image 1 of 2 InFocus LP540 Projector Lens Replacement: step 8, image 2 of 2
    • Carefully hold the lens from both ends and lift up simultaneously
Jorge L Navarro
533 Reputation
5 Guides authored
Cal Poly, Team 13-17, Regan Winter 2014 Member of Cal Poly, Team 13-17, Regan Winter 2014
CPSU-REGAN-W14S13G17
6 Members
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 20
All Time: 2,599
