InFocus LP540 Projector Speakers Replacement
  1. InFocus LP540 Projector Speakers Replacement, Speakers: step 1, image 1 of 3 InFocus LP540 Projector Speakers Replacement, Speakers: step 1, image 2 of 3 InFocus LP540 Projector Speakers Replacement, Speakers: step 1, image 3 of 3
    • Flip the projector right-side up and turn it so the backports face you.
    • Remove the 7mm metallic hex screws using the screwdriver.
    • Remove the two black 10mm screws using the T10 Torx screwdriver head. The screws are located at the center of the back panel.
  2. InFocus LP540 Projector Speakers Replacement: step 2, image 1 of 2 InFocus LP540 Projector Speakers Replacement: step 2, image 2 of 2
    • Remove the two 77mm screws that are located nearest to the back panel ports using a T10 Torx screwdriver.
    • Remove the two 10mm screws located near the lens side with the T10 Torx screwdriver.
    • Flip the projector back over.
    • Cautiously lift the main lid to avoid ripping the electrical strips.
  3. InFocus LP540 Projector Speakers Replacement: step 3, image 1 of 2 InFocus LP540 Projector Speakers Replacement: step 3, image 2 of 2
    • Unplug the speaker wire from the circuit board by squeezing the sides and pulling.
    • Pull on the brown tabs located at the sides of the white plastic ribbon holder and pull the ribbon out.
  4. InFocus LP540 Projector Speakers Replacement: step 4, image 1 of 3 InFocus LP540 Projector Speakers Replacement: step 4, image 2 of 3 InFocus LP540 Projector Speakers Replacement: step 4, image 3 of 3
    • Place the top shell of the projector down.
    • Remove the speaker wires from the white tabs.
    • Use a Phillips #0 screwdriver to remove the four 5.5 mm screws.
    • Carefully lift the speakers to remove them.
Reassembly: Close the speaker compartment and replace the light cover. Screw it back into place to secure all parts.
Jorge L Navarro
533 Reputation
5 Guides authored
Cal Poly, Team 13-17, Regan Winter 2014 Member of Cal Poly, Team 13-17, Regan Winter 2014
CPSU-REGAN-W14S13G17
6 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 30
All Time: 777
