Infant Optics DXR-8 Charging Port Replacement
  1. Infant Optics DXR-8 Charging Port Replacement, Internal Monitor Components: step 1, image 1 of 3 Infant Optics DXR-8 Charging Port Replacement, Internal Monitor Components: step 1, image 2 of 3 Infant Optics DXR-8 Charging Port Replacement, Internal Monitor Components: step 1, image 3 of 3
    • Using the plastic opening tool, remove screen protector from front of monitor.
  2. Infant Optics DXR-8 Charging Port Replacement: step 2, image 1 of 3 Infant Optics DXR-8 Charging Port Replacement: step 2, image 2 of 3 Infant Optics DXR-8 Charging Port Replacement: step 2, image 3 of 3
    • Remove the six 4mm screws using a Phillips #00 screwdriver.
    • Remove the screen, exposing the circuit board.
    • Turn device over to expose rear circuit board.
  3. Infant Optics DXR-8 Charging Port Replacement: step 3, image 1 of 3 Infant Optics DXR-8 Charging Port Replacement: step 3, image 2 of 3 Infant Optics DXR-8 Charging Port Replacement: step 3, image 3 of 3
    • Disconnect speaker from monitor for ease of access by unplugging wire.
  4. Infant Optics DXR-8 Charging Port Replacement, Charging Port: step 4, image 1 of 2 Infant Optics DXR-8 Charging Port Replacement, Charging Port: step 4, image 2 of 2
    • Unscrew the four 3 mm screws holding the motherboard to the unit using a Phillips #00 screwdriver.
  5. Infant Optics DXR-8 Charging Port Replacement: step 5, image 1 of 2 Infant Optics DXR-8 Charging Port Replacement: step 5, image 2 of 2
  6. Infant Optics DXR-8 Charging Port Replacement: step 6, image 1 of 1
    • Remove the old charging port and solder the new one in place.
  7. Infant Optics DXR-8 Charging Port Replacement: step 7, image 1 of 1
    • Flip the unit over to ensure a correct fitment.
Donovan Zusalim
300 Reputation
1 Guide authored
Cal Poly, Team 13-4, Banghart Winter 2017 Member of Cal Poly, Team 13-4, Banghart Winter 2017
CPSU-BANGHART-W17S13G4
4 Members
4 Guides authored
3 Comments
I appreciate you posting this. What kind of new charging port did you use (USB type, size, etc) and does IFIXIT sell them?
John Lynch - Reply
The part you are looking for is a female Micro USB B-Type solder socket. I no longer have the unit available to confirm, but I'll bet you could contact Infant Optics and confirm with them. Sorry I can't be of more help!
Donovan Zusalim -
Worth pointing out that this guide shows an older version of the DXR-8 (2014 printed on the PCB) where the microUSB port uses through-hole leads to connect to the board. Mine is a few years newer and the port was surface-mounted, which requires more skill and care to replace. I ended up ordering the part myself and taking it to a repair shop for them to do the soldering.
Danny Conrad - Reply
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 46
All Time: 6,219
