Infant Optics DXR-8 Speaker Replacement
  1. Infant Optics DXR-8 Speaker Replacement, Internal Monitor Components: step 1, image 1 of 3 Infant Optics DXR-8 Speaker Replacement, Internal Monitor Components: step 1, image 2 of 3 Infant Optics DXR-8 Speaker Replacement, Internal Monitor Components: step 1, image 3 of 3
    • Using the plastic opening tool, remove screen protector from front of monitor.
  2. Infant Optics DXR-8 Speaker Replacement: step 2, image 1 of 3 Infant Optics DXR-8 Speaker Replacement: step 2, image 2 of 3 Infant Optics DXR-8 Speaker Replacement: step 2, image 3 of 3
    • Remove the six 4mm screws using a Phillips #00 screwdriver.
    • Remove the screen, exposing the circuit board.
    • Turn device over to expose rear circuit board.
  3. Infant Optics DXR-8 Speaker Replacement: step 3, image 1 of 3 Infant Optics DXR-8 Speaker Replacement: step 3, image 2 of 3 Infant Optics DXR-8 Speaker Replacement: step 3, image 3 of 3
    • Disconnect speaker from monitor for ease of access by unplugging wire.
  4. Infant Optics DXR-8 Speaker Replacement, Speaker: step 4, image 1 of 1
    • Use a heat gun to soften and easily remove epoxy that surrounds the speaker. Gently scrape it free little by little with metal spudger.
  5. Infant Optics DXR-8 Speaker Replacement: step 5, image 1 of 1
    • Lift the speaker from casing using metal spudger.
    • Place new 8W speaker in the casing and connect wire.
3 other people completed this guide.
Larsha Johnson
526 Reputation
3 Guides authored
USF Tampa, Team 6-4, Remmell Fall 2015 Member of USF Tampa, Team 6-4, Remmell Fall 2015
USFT-REMMELL-F15S6G4
4 Members
3 Guides authored
5 Comments
Where to purchase the replacement speaker?
Keiundra Joiner - Reply
Where can we purchase the replacement 8w speaker part
lea placek - Reply
8W Speaker is incorrect.
The speaker needed is 8 Ohm 0.5 Watt.
Ryan Ernde - Reply
Thanks for this. Found something on Ali Express, just need to figure out the right size
https://www.aliexpress.us/item/325680361...
itryit -
This is good to show how you get it open. Unless you have a speaker that has the plastic piece that connects to the mother board, then it’s useless. The speaker I ordered just had two free standing wires.
Mark Ruddy - Reply
Past 24 Hours: 0
Past 7 Days: 14
Past 30 Days: 81
All Time: 16,963
