Infiniti Q50 Bottom Screen Display Replacement
  1. Infiniti Q50 Bottom Screen Display Replacement, Bottom Screen Display: step 1, image 1 of 3 Infiniti Q50 Bottom Screen Display Replacement, Bottom Screen Display: step 1, image 2 of 3 Infiniti Q50 Bottom Screen Display Replacement, Bottom Screen Display: step 1, image 3 of 3
    • Use a panel popper or screwdriver to pop out the side panels of the center console.
  2. Infiniti Q50 Bottom Screen Display Replacement: step 2, image 1 of 3 Infiniti Q50 Bottom Screen Display Replacement: step 2, image 2 of 3 Infiniti Q50 Bottom Screen Display Replacement: step 2, image 3 of 3
    • Lift and remove the cup holder piece.
  3. Infiniti Q50 Bottom Screen Display Replacement: step 3, image 1 of 1
    • Push down on the gear shift to reveal the clip.
  4. Infiniti Q50 Bottom Screen Display Replacement: step 4, image 1 of 1
    • Make sure to engage your emergency brakes and put the car in neutral gear before proceeding with this step.
    • Use a screwdriver to remove the clip from the gear shift.
    • Store this clip in a secure location for safekeeping.
    • Pull off the gear shift knob.
  5. Infiniti Q50 Bottom Screen Display Replacement: step 5, image 1 of 2 Infiniti Q50 Bottom Screen Display Replacement: step 5, image 2 of 2
    • Remove the two screws found underneath the side panels.
  6. Infiniti Q50 Bottom Screen Display Replacement: step 6, image 1 of 1
    • Wiggle to lift the center console over the gear shift.
  7. Infiniti Q50 Bottom Screen Display Replacement: step 7, image 1 of 2 Infiniti Q50 Bottom Screen Display Replacement: step 7, image 2 of 2
    • Pinch the tip of each connector cord to detach from the center console.
  8. Infiniti Q50 Bottom Screen Display Replacement: step 8, image 1 of 3 Infiniti Q50 Bottom Screen Display Replacement: step 8, image 2 of 3 Infiniti Q50 Bottom Screen Display Replacement: step 8, image 3 of 3
    • Pull off the trim found on either side of the display screen.
  9. Infiniti Q50 Bottom Screen Display Replacement: step 9, image 1 of 2 Infiniti Q50 Bottom Screen Display Replacement: step 9, image 2 of 2
    • Remove the two screws underneath the trim.
  10. Infiniti Q50 Bottom Screen Display Replacement: step 10, image 1 of 2 Infiniti Q50 Bottom Screen Display Replacement: step 10, image 2 of 2
    • Wiggle to pull out the bottom screen display.
  11. Infiniti Q50 Bottom Screen Display Replacement: step 11, image 1 of 2 Infiniti Q50 Bottom Screen Display Replacement: step 11, image 2 of 2
    • Pinch to detach the connector cords.
Roberta Willis
233 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 40
All Time: 830
