Innioasis Y1 SD Card Replacement
  1. Innioasis Y1 SD Card Replacement, Open The Case: step 1, image 1 of 3 Innioasis Y1 SD Card Replacement, Open The Case: step 1, image 2 of 3 Innioasis Y1 SD Card Replacement, Open The Case: step 1, image 3 of 3
    • Use a pry tool and start half way up the left or right side of the MP3 player, working your way around the edge
    • Carefully lift the cover off and detach the connecting cable
  2. Innioasis Y1 SD Card Replacement, Remove the Main Board: step 2, image 1 of 3 Innioasis Y1 SD Card Replacement, Remove the Main Board: step 2, image 2 of 3 Innioasis Y1 SD Card Replacement, Remove the Main Board: step 2, image 3 of 3
    • Remove the 3 screws with a Philips #00
    • Carefully remove the Speak from its clasps with a pry tool
    • Carefully lift the board on the left side with the pry tool
  3. Innioasis Y1 SD Card Replacement, Flip the Board: step 3, image 1 of 3 Innioasis Y1 SD Card Replacement, Flip the Board: step 3, image 2 of 3 Innioasis Y1 SD Card Replacement, Flip the Board: step 3, image 3 of 3
    • Carefully Lift the board up and towards the screen. You may need to lightly pry the battery out of its socket
    • Remove the tape
    • Slide the Micro SD card out of the socket
3 other people completed this guide.
Dan
4,433 Reputation
9 Guides authored
4 Comments
Tired of waiting for a reaction to my questions above I bought a Samsung 512GB Micro SD Evo Plus UHS-I U3 SDcard. Maybe overkill, but very fast. the replacement of the card was a 5 minutes job. Now I am copying the contents of the old 128GB card to the Innioasis Y3 which will take hours I guess. I let everyone know if it all works fine.
P. Reuvers - Reply
It works great. Only one small issue. The Innioasis Y1 shows that it contain 128GB, But he shows the correct used and available space, at this moment I used 143GB of the 512GB, more then the original Innioasis Y1.
P. Reuvers -
Any suggestion on how to format the SD Card? thanks
Paninaro -
Will this work with an ExFAT format card or just FAT32? Thanks
jjedwards894 - Reply
Past 24 Hours: 8
Past 7 Days: 69
Past 30 Days: 264
All Time: 3,395
