Insignia 6-Quart Pressure Cooker Circuit Board Replacement
  1. Insignia 6-Quart Pressure Cooker Circuit Board Replacement, Circuit Board and Power Cord: step 1, image 1 of 1
    • Use a Phillips head #2 screwdriver to remove the 6mm screw.
  2. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: step 2, image 1 of 1
    • Twist the light grey plastic until the holes align with the blockers.
    • Remove the light grey plastic cover.
  3. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: step 3, image 1 of 1
    • Remove the power cord from the slot it is inserted in.
  4. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: step 4, image 1 of 1
    • Use a Phillips head #2 screwdriver to remove the 22mm screw connected to the black wire.
  5. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: step 5, image 1 of 1
    • Use a Phillips head #2 screwdriver to remove the 8mm screw and it's washer from the red wire.
  6. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: step 6, image 1 of 1
    • Use a Phillips head #2 screwdriver to remove the 8mm screw and it's washer from the blue wire.
  7. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: step 7, image 1 of 1
    • Pinch the small white component connected to the circuit board.
    • Once pinched, wiggle this component until it is disconnected.
  8. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: step 8, image 1 of 1
    • Pinch the red component connected to the circuit board.
  9. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: step 9, image 1 of 1
    • Wiggle the wide white component until it is removed from the circuit board.
  10. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: step 10, image 1 of 1
    • Use a J1 head screwdriver to remove the 8mm screws from both sides of the circuit board.
  11. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: step 11, image 1 of 1
    • Use a Phillips head #2 screwdriver to remove both 15mm screws from either side of the circuit board, indicated in the picture.
  12. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: step 12, image 1 of 1
    • Position the pressure cooker so that the circuit board is farther from you then the black, red, and blue wire connections.
    • To the right of the board, use a Phillips head #2 screwdriver to remove the 6mm screw.
  13. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: step 13, image 1 of 1
    • Use a Phillips head #2 screwdriver to remove the 6mm screw behind and to the right of the circuit board tray.
  14. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: step 14, image 1 of 1
    • Remove and replace the circuit board.
5 other people completed this guide.
Savannah Webb
657 Reputation
5 Guides authored
Cal Poly, Team S12-G3, Banghart Winter 2018 Member of Cal Poly, Team S12-G3, Banghart Winter 2018
CPSU-BANGHART-W18S12G3
4 Members
5 Guides authored
8 Comments
Where do you purchase the circuit board
Douglas Koons - Reply
Hi, thanks for the guide. Where could I purchase the circuit board?
Anthea - Reply
Please, Where can I buy the electrical circuit?
Mohammed - Reply
why is my circuit board not fixed to the top like in the diagram
david stanley - Reply
where can I purchase the circuit board
de27@bellsouth.net - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 21
All Time: 3,223
