Insignia Flex 8 Battery Replacement
  1. Insignia Flex 8 Battery Replacement, Battery: step 1, image 1 of 1
    • Make sure the power is off to avoid injury in the following steps.
    • Position the tablet so that the screen is face down.
    • The power button is located in the upper left hand corner.
    • Hold the power button for three seconds until the tablet powers down.
  2. Insignia Flex 8 Battery Replacement: step 2, image 1 of 2 Insignia Flex 8 Battery Replacement: step 2, image 2 of 2
    • Remove the back casing by sliding a credit card or a similarly thin but firm object in between the casing and the screen.
    • Run this object around the perimeter of the tablet until there is separation between the casing and the screen.
    • Remove the back casing and set aside.
  3. Insignia Flex 8 Battery Replacement: step 3, image 1 of 1
    • Peel back the tape from battery and case.
  4. Insignia Flex 8 Battery Replacement: step 4, image 1 of 1
    • Slide the spudger beneath battery to pry away it away from the case. Work around the battery, prying up all edges to remove from glue.
    • Do not puncture or bend battery. This could cause battery to leak acid.
  5. Insignia Flex 8 Battery Replacement: step 5, image 1 of 1
    • Desolder the black, yellow and red connections from circuit board. Desoldering Help
    • Keep the soldering tool away from other components on the circuit board.
4 other people completed this guide.
Tyler Tyrrell
890 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 9,270
