Insignia Flex 8 Screen Replacement
  1. Insignia Flex 8 Screen Replacement, Circuit Board: step 1, image 1 of 1
    • Turn off the power to your tablet to avoid injury.
    • Position the tablet so that the screen is face down and the power button is located in the upper left hand corner.
    • Hold down the power button for five seconds until the tablet powers down.
  2. Insignia Flex 8 Screen Replacement: step 2, image 1 of 2 Insignia Flex 8 Screen Replacement: step 2, image 2 of 2
    • Remove the back casing from the screen by sliding a credit card or a similarly thin but firm object in between the casing and the screen.
    • You may need to use a spudger to initially create separation between the screen and the casing.
    • Run this object around the perimeter of the tablet until there is separation between the casing and the screen.
    • Remove the back casing and set aside.
  3. Insignia Flex 8 Screen Replacement: step 3, image 1 of 2 Insignia Flex 8 Screen Replacement: step 3, image 2 of 2
    • Peel tape off of ribbon connectors. Starting at the power button, work clockwise around the tablet.
  4. Insignia Flex 8 Screen Replacement: step 4, image 1 of 3 Insignia Flex 8 Screen Replacement: step 4, image 2 of 3 Insignia Flex 8 Screen Replacement: step 4, image 3 of 3
    • To remove the camera ribbon cable, lift the flap using a spudger.
    • Pull the ribbon directly back to release it.
  5. Insignia Flex 8 Screen Replacement: step 5, image 1 of 3 Insignia Flex 8 Screen Replacement: step 5, image 2 of 3 Insignia Flex 8 Screen Replacement: step 5, image 3 of 3
    • Remove the second ribbon cable by prying up the black flap using a spudger.
    • Pull the ribbon cable horizontally directly away from the battery.
  6. Insignia Flex 8 Screen Replacement: step 6, image 1 of 3 Insignia Flex 8 Screen Replacement: step 6, image 2 of 3 Insignia Flex 8 Screen Replacement: step 6, image 3 of 3
    • Remove the final ribbon cable by pulling back the two black tabs on either side of the ribbon cable.
    • Pull the ribbon horizontally directly away from the battery.
  7. Insignia Flex 8 Screen Replacement: step 7, image 1 of 2 Insignia Flex 8 Screen Replacement: step 7, image 2 of 2
    • Unscrew the thirteen 4.75mm screws around the perimeter of the tablet using a PH 00 screwdriver.
  8. Insignia Flex 8 Screen Replacement: step 8, image 1 of 2 Insignia Flex 8 Screen Replacement: step 8, image 2 of 2
    • Unscrew the four 3.75mm screws and plastic washers using a PH 00 screwdriver.
    • Lift up the circuit board.
  9. Insignia Flex 8 Screen Replacement: step 9, image 1 of 1
    • Unscrew the final two screws that were underneath the circuit board.
    • These screws are near the charging port and USB adapter.
    • These screws are also 3.75mm and can be interchanged with the second set of screws only.
  10. Insignia Flex 8 Screen Replacement: step 10, image 1 of 1
    • Lift the circuit board and black internal mounting piece away from the screen.
    • Set the circuit board aside.
    • Be careful of the soldered antenna as you separate the pieces.
    • Be careful of the soldered ribbon that is connected to the power source. This ribbon is fragile.
  11. Insignia Flex 8 Screen Replacement, Screen: step 11, image 1 of 1
    • Slide the spudger in between the silver screen and the black border
  12. Insignia Flex 8 Screen Replacement: step 12, image 1 of 1
    • Pry up the LCD display and lift it away from the plastic screen.
5 other people completed this guide.
Tyler Tyrrell
890 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 3
Past 30 Days: 12
All Time: 8,238
