Insignia NS-B2110 Battery Replacement
  1. Insignia NS-B2110 Battery Replacement, Battery: step 1, image 1 of 2 Insignia NS-B2110 Battery Replacement, Battery: step 1, image 2 of 2
    • Flip the stereo so the CD opening is face down.
    • With two fingers, pinch the tabs and lift up to open the battery protection cover.
  2. Insignia NS-B2110 Battery Replacement: step 2, image 1 of 2 Insignia NS-B2110 Battery Replacement: step 2, image 2 of 2
    • Using a spudger or your fingers, push up against the positive end of the battery. Once it is loose, lift the battery out.
    • Repeat until all eight batteries are removed.
    • Make sure the batteries are facing the right direction. If the device does not turn on, you may have the batteries in the opposite orientation.
Daniel Hodges
301 Reputation
3 Guides authored
Cal Poly, Team 4-31, Amido Fall 2013 Member of Cal Poly, Team 4-31, Amido Fall 2013
CPSU-AMIDO-F13S4G31
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 366
