Insignia NS-B4111 Casing Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Insignia NS-B4111 Casing  Replacement, Casing: step 1, image 1 of 1
    • Turn the boombox upside down again. With the Phillips PH1 or the Flathead #3 screwdriver, remove the three 14mm black screws.
    • Remove the four 18mm chrome screws with the Phillips PH1 screwdriver.
  2. Insignia NS-B4111 Casing  Replacement: step 2, image 1 of 2 Insignia NS-B4111 Casing  Replacement: step 2, image 2 of 2
    • Gently remove the bottom half of the casing from the top half of the casing.
    • The antenna base is connected to the motherboard by a red wire. This wire will prevent the two halves from separating completely.
Kristin Yoshioka
984 Reputation
9 Guides authored
UC Davis, Team 1-5, Oliver Fall 2016 Member of UC Davis, Team 1-5, Oliver Fall 2016
UCD-OLIVER-F16S1G5
5 Members
11 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 3
All Time: 86
