Insignia NS-B4111 Motherboard Replacement
  1. Insignia NS-B4111 Motherboard Replacement, Battery: step 1, image 1 of 2 Insignia NS-B4111 Motherboard Replacement, Battery: step 1, image 2 of 2
    • Unplug and remove the power cord. Turn the boombox upside down.
    • Grip the sides of the case and use your thumbs to pop open the battery cover.
  2. Insignia NS-B4111 Motherboard Replacement: step 2, image 1 of 2 Insignia NS-B4111 Motherboard Replacement: step 2, image 2 of 2
    • Pry out the batteries with your fingers.
  3. Insignia NS-B4111 Motherboard Replacement, Casing: step 3, image 1 of 1
    • Turn the boombox upside down again. With the Phillips PH1 or the Flathead #3 screwdriver, remove the three 14mm black screws.
    • Remove the four 18mm chrome screws with the Phillips PH1 screwdriver.
  4. Insignia NS-B4111 Motherboard Replacement: step 4, image 1 of 2 Insignia NS-B4111 Motherboard Replacement: step 4, image 2 of 2
    • Gently remove the bottom half of the casing from the top half of the casing.
    • The antenna base is connected to the motherboard by a red wire. This wire will prevent the two halves from separating completely.
  5. Insignia NS-B4111 Motherboard Replacement, Antenna Base: step 5, image 1 of 2 Insignia NS-B4111 Motherboard Replacement, Antenna Base: step 5, image 2 of 2
    • Remove the 10mm chrome screw from the antenna base with the Phillips PH1 screwdriver. Remove the antenna base from the casing.
    • This red wire will now be loose and you can move it out of the antenna base slot.
  6. Insignia NS-B4111 Motherboard Replacement, Motherboard: step 6, image 1 of 1
    • Unscrew the four 12.5mm screws with the Phillips PH1 Screwdriver.
    • Unscrew the one 10mm long screw with the Phillips PH1 Screwdriver.
  7. Insignia NS-B4111 Motherboard Replacement: step 7, image 1 of 1
    • Orient the device so that the back is facing you.
    • Unplug the six pin male/female header from its socket on the motherboard. The wires on the header are these colors: burgundy, red, orange, yellow, green, and blue.
    • Use a tweezer if you find it hard to pull the header out with your fingers.
    • Gently pull out the ribbon cable from its socket on the motherboard.
    • Pay attention to the orientation of the header and the ribbon cable. Replacing the wires the wrong way may short circuit the board.
  8. Insignia NS-B4111 Motherboard Replacement: step 8, image 1 of 1
    • Rotate the device so that the front is facing you.
    • Unplug the four pin header from its socket on the motherboard. The wires on the header are these colors: brown, red, orange, and yellow.
    • Use a tweezer if you find it hard to pull this header out with your fingers.
    • Gently pull out the ribbon cable from its socket.
    • Pay attention to the orientation of the header and the ribbon cable. Replacing the base the wrong way may short circuit the board.
  9. Insignia NS-B4111 Motherboard Replacement: step 9, image 1 of 1
    • Pull out the two pin header from its socket on the motherboard. The wires on this header are black and white.
    • Use a tweezer if you find it hard to pull this cable out with your fingers.
  10. Insignia NS-B4111 Motherboard Replacement, Motherboard: step 10, image 1 of 1
    • Scrape off the glue from the black wire with the blue plastic opening tool.
  11. Insignia NS-B4111 Motherboard Replacement: step 11, image 1 of 2 Insignia NS-B4111 Motherboard Replacement: step 11, image 2 of 2
    • Desolder the one black, one red, and two blue wires. If you need help soldering, see this guide.
Kristin Yoshioka
984 Reputation
9 Guides authored
UC Davis, Team 1-5, Oliver Fall 2016 Member of UC Davis, Team 1-5, Oliver Fall 2016
UCD-OLIVER-F16S1G5
5 Members
11 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 17
All Time: 1,102
