Insignia NS-CLIP02 Motherboard Replacement
Erik
Erik and 6 other contributors
Last updated on June 29, 2023
30 - 50 minutes
Moderate
Slice and Dice
Step Trimmer
Introduction
Go to step 1
This guide will demonstrate how to replace the motherboard of an Insignia NS-CLIP02. If your Insignia NS-CLIP02 is not performing as it should and you have already tried all of the troubleshooting tips, the motherboard may need to be replaced. The motherboard is an essential part of any device, and it is what keeps the device working well and it allows each individual part of the device to interact with each other. However, only replace the motherboard of the Insignia NS-CLIP02 if the device truly is not working and you have gone through all of the troubleshooting guides. Make sure the device is powered off/not plugged in before you begin the motherboard replacement.
Tools
Show more…
  1. Insignia NS-CLIP02 Motherboard Replacement, Motherboard: step 1, image 1 of 1
    • Set the clock radio on the work space so the bottom of the device is showing.
  2. Insignia NS-CLIP02 Motherboard Replacement: step 2, image 1 of 2 Insignia NS-CLIP02 Motherboard Replacement: step 2, image 2 of 2
    • Use a metal spudger to peel back the adhesive sticker on the bottom of the clock.
    • You should see a single screw beneath the sticker.
  3. Insignia NS-CLIP02 Motherboard Replacement: step 3, image 1 of 2 Insignia NS-CLIP02 Motherboard Replacement: step 3, image 2 of 2
    • Using a plastic opening tool, peel off the adhesive gel stoppers.
  4. Insignia NS-CLIP02 Motherboard Replacement: step 4, image 1 of 1
    • Use a Phillips screwdriver to remove the six 11 mm screws on the bottom of the device.
  5. Insignia NS-CLIP02 Motherboard Replacement: step 5, image 1 of 1
    • Remove the bottom cover from the device to reveal the motherboard.
  6. Insignia NS-CLIP02 Motherboard Replacement: step 6, image 1 of 1
    • Use a Phillips screwdriver to remove the 9.5 mm screw located near the center of the motherboard.
  7. Insignia NS-CLIP02 Motherboard Replacement: step 7, image 1 of 1
    • Lift the motherboard away from the device.
  8. Insignia NS-CLIP02 Motherboard Replacement: step 8, image 1 of 3 Insignia NS-CLIP02 Motherboard Replacement: step 8, image 2 of 3 Insignia NS-CLIP02 Motherboard Replacement: step 8, image 3 of 3
    • Disconnect the four cables connecting the motherboard to the device.
Erik
405 Reputation
4 Guides authored
USF Tampa, Team 9-3, Leahy Winter 2015 Member of USF Tampa, Team 9-3, Leahy Winter 2015
USFT-LEAHY-W15S9G3
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 6
All Time: 180
