Insignia NS-CLIP02 Speaker replacement and troubleshooting
  1. Insignia NS-CLIP02 Speaker replacement and troubleshooting, Motherboard: step 1, image 1 of 1
    • Set the clock radio on the work space so the bottom of the device is showing.
  2. Insignia NS-CLIP02 Speaker replacement and troubleshooting: step 2, image 1 of 2 Insignia NS-CLIP02 Speaker replacement and troubleshooting: step 2, image 2 of 2
    • Use a metal spudger to peel back the adhesive sticker on the bottom of the clock.
    • You should see a single screw beneath the sticker.
  3. Insignia NS-CLIP02 Speaker replacement and troubleshooting: step 3, image 1 of 2 Insignia NS-CLIP02 Speaker replacement and troubleshooting: step 3, image 2 of 2
    • Using a plastic opening tool, peel off the adhesive gel stoppers.
  4. Insignia NS-CLIP02 Speaker replacement and troubleshooting: step 4, image 1 of 1
    • Use a Phillips screwdriver to remove the six 11 mm screws on the bottom of the device.
  5. Insignia NS-CLIP02 Speaker replacement and troubleshooting: step 5, image 1 of 1
    • Remove the bottom cover from the device to reveal the motherboard.
  6. Insignia NS-CLIP02 Speaker replacement and troubleshooting: step 6, image 1 of 1
    • Use a Phillips screwdriver to remove the 9.5 mm screw located near the center of the motherboard.
  7. Insignia NS-CLIP02 Speaker replacement and troubleshooting: step 7, image 1 of 1
    • Lift the motherboard away from the device.
  8. Insignia NS-CLIP02 Speaker replacement and troubleshooting: step 8, image 1 of 3 Insignia NS-CLIP02 Speaker replacement and troubleshooting: step 8, image 2 of 3 Insignia NS-CLIP02 Speaker replacement and troubleshooting: step 8, image 3 of 3
    • Disconnect the four cables connecting the motherboard to the device.
  9. Insignia NS-CLIP02 Speaker replacement and troubleshooting, Speaker: step 9, image 1 of 1
    • Remove the three screws located along the center of the base.
  10. Insignia NS-CLIP02 Speaker replacement and troubleshooting: step 10, image 1 of 2 Insignia NS-CLIP02 Speaker replacement and troubleshooting: step 10, image 2 of 2
    • Remove the base from the display.
  11. Insignia NS-CLIP02 Speaker replacement and troubleshooting: step 11, image 1 of 3 Insignia NS-CLIP02 Speaker replacement and troubleshooting: step 11, image 2 of 3 Insignia NS-CLIP02 Speaker replacement and troubleshooting: step 11, image 3 of 3
    • Using a metal spudger, remove the plastic face plate from the display.
  12. Insignia NS-CLIP02 Speaker replacement and troubleshooting: step 12, image 1 of 1
    • With a phillips screwdriver, remove the six screws shown pictured to the left.
  13. Insignia NS-CLIP02 Speaker replacement and troubleshooting: step 13, image 1 of 2 Insignia NS-CLIP02 Speaker replacement and troubleshooting: step 13, image 2 of 2
    • Using the metal spudger, pry the speaker grilles from the display.
  14. Insignia NS-CLIP02 Speaker replacement and troubleshooting: step 14, image 1 of 1
    • Using the phillips screwdriver, remove the four screws pictured to the left.
  15. Insignia NS-CLIP02 Speaker replacement and troubleshooting: step 15, image 1 of 1
    • Separate the two pieces of the display as shown.
  16. Insignia NS-CLIP02 Speaker replacement and troubleshooting: step 16, image 1 of 3 Insignia NS-CLIP02 Speaker replacement and troubleshooting: step 16, image 2 of 3 Insignia NS-CLIP02 Speaker replacement and troubleshooting: step 16, image 3 of 3
    • You can see that there are several points where connections to the speaker are soldered.
    • If all connections are soldered then replacement may be necessary.
Aubrey
214 Reputation
2 Guides authored
USF Tampa, Team 9-3, Leahy Winter 2015 Member of USF Tampa, Team 9-3, Leahy Winter 2015
USFT-LEAHY-W15S9G3
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 184
