Insignia NS-CSPBTHOL-R Speakers Replacement
  1. Insignia NS-CSPBTHOL-R Speakers Replacement, Speakers: step 1, image 1 of 1
    • Insert the Spudger between the grated panel and the base of the speaker.
  2. Insignia NS-CSPBTHOL-R Speakers Replacement: step 2, image 1 of 1
    • Pull the grated panel off
  3. Insignia NS-CSPBTHOL-R Speakers Replacement: step 3, image 1 of 1
    • Remove the six 3mm screws using the J00 JIS screw bit. This will require a long, narrow screwdriver.
  4. Insignia NS-CSPBTHOL-R Speakers Replacement: step 4, image 1 of 1
    • Insert the Spudger between the corners of base and the face of the speaker to open the device.
    • The screw on the upper right corner may be difficult to take out. If you cannot take it out with a screwdriver, using force to pull the face of the speaker apart may break the plastic that surrounds the screw.
  5. Insignia NS-CSPBTHOL-R Speakers Replacement: step 5, image 1 of 1
    • Remove one speaker at a time
  6. Insignia NS-CSPBTHOL-R Speakers Replacement: step 6, image 1 of 1
    • Grab the back piece of the speaker and gently pull upward.
  7. Insignia NS-CSPBTHOL-R Speakers Replacement: step 7, image 1 of 1
    • Remove speakers gently one at a time.
  8. Insignia NS-CSPBTHOL-R Speakers Replacement: step 8, image 1 of 3 Insignia NS-CSPBTHOL-R Speakers Replacement: step 8, image 2 of 3 Insignia NS-CSPBTHOL-R Speakers Replacement: step 8, image 3 of 3
    Tool used on this step:
    Buy
    • Using blunted tip tweezers, squeeze and pull on the white plastic clip. This will separate the speaker's wires from the motherboard.
    • The wires are connected to the white plastic clip that is attached to the motherboard.
Lheessis Ruiz
101 Reputation
1 Guide authored
USF Tampa, Team 12-6, Eyestone Spring 2017 Member of USF Tampa, Team 12-6, Eyestone Spring 2017
USFT-EYESTONE-S17S12G6
3 Members
4 Guides authored
One Comment
This is a good app really could help some people like myself. Thank you
rrguerrero7330 - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 659
