Insignia NS-F12R6-SS Fan Blade Replacement
  1. Insignia NS-F12R6-SS Fan Blade Replacement, Front Cage: step 1, image 1 of 2 Insignia NS-F12R6-SS Fan Blade Replacement, Front Cage: step 1, image 2 of 2
    • Unplug your fan.
    • Remove the 20 mm bolt that fastens the fan ring located at the bottom of the fan cage with a Phillips #3 screwdriver.
  2. Insignia NS-F12R6-SS Fan Blade Replacement: step 2, image 1 of 1
    • Remove the ring that runs around the edge of the fan cage.
  3. Insignia NS-F12R6-SS Fan Blade Replacement: step 3, image 1 of 1
    • Remove the front of the fan cage.
  4. Insignia NS-F12R6-SS Fan Blade Replacement, Fan Blade: step 4, image 1 of 1
    • Remove the 8 mm bolt fastening the fan blades to the rotor with a Phillip #3 screwdriver.
  5. Insignia NS-F12R6-SS Fan Blade Replacement: step 5, image 1 of 1
    • Take caution when removing the fan blades. They can be sharp!
    • Slide the fan blade off the end of the rotor.
Hank
1,142 Reputation
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 378
